Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • It's not in rc5 - you need to build from source right now if you want to use it.
  • HI Dev's, are we close to RC6 (or a release). RC5 is working great on my hex, Cheers and thanks! MIke
    • Excited for when the stable release is out. Im a bit scared to run the beta on my quad, am £ being silly worrying?
      • Hmm tough one, personally I thrust the RC5 release. There is no guarantee though as most builds are different, but as I said it works for me! ;-)
        • Hey Mike. Upgraded to Rc5 this arvo. Installed my lidar-lite in PWM mode and carried out a autotune. All went perfect.
        • This reply was deleted.
          • Yeah sure; I have a Tarot 680Pro with Emax 3510's and 13CF props, HK 30A SimonK ESC's, 3DR Pixhawk (2 x GPS M8N & 3DR) and FrySky radio gear. I run 4s Batteries.
            Cheers, Mike
  • Pixhawk 3.3 RC5 and Mission planner 1.3.28.4
    Trying to use RC6 channel on AUX output to command a gimbal.
    I can see clearly that RC6 is active on the radio calibration screen. So pixhawk "sees" correctly this channel
    trying to use RC10:3702025023?profile=original
    Connecting an oscilloscope on RC9 10 11 12 to "see" what pixhawk is sending on these channels. Trying to map Rx RC6 to RC10 using the Mission planner camera setup as follows:
    3702025092?profile=original
    And checking in mission planner that everything is ok:
    3702025044?profile=original
    Everything looks ok... But it does not work. Surely I'm doing something wrong but what?
    I tried 1 for pass through.. Doesn't work either..
    Thank you in advance
    Henri
      Henry,
         Probably just need to set the MNT_TYPE parameter to "1".  This is new for AC3.3.  In the next release candidate this will be defaulted to "1" if people have been using a servo gimbal in AC3.2.1 so people shouldn't hit this problem.
      • @Randy: Thank you for answering. Could you please indicate which (or where) can I find MNT_TYPE?
        Thank you in advance.
        Regards
        Henri
        3702703028?profile=original
        3702703362?profile=original
        • AND... At the bottom *is* MNT_TYPE..
