Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I have been flying with rc10 since it came out and everything was fine till today.
    I was on my second battery of the night and after 5-6 minutes for some reason my Y6b suddenly rolled/yawed in place and then would straighten out again. This was in stab mode with simple mode on. This happened several time and then the copter seamed to loose power and started slowly decending. I was still able to apply roll and pitch but it ended up coming all the way down and flipping over when it hit the ground.
    After the crash I noticed that the GPS mast was a little bit loose and could easily twist 5-10 degrees. Not sure if this was caused by the crash or went loose during the flight.
    attached is the log from that flight.
    Any thoughts/insights would be greatly appreciated.
    • hmn log file didn't seam to attach so here it is via google drive
      https://drive.google.com/file/d/0B9lPaNf0CEySMGFLRy15WW00bzQ/view?u...
      37.BIN
        Yssaril,
        Thanks for testing.
        Looks like motor #4 (bottom back) is failing.  It shows the classic signs which is sudden separation of the desired-pitch vs actual-pitch (it suddenly pitches back which is consistent with a rear motor failure) and the output sent to the back motor goes to full (i.e. it's trying to get more power out of the motor but it's not).
  • What is the best way to bias the EKF towards the IMU a bit more (or in other words, less wieghting on GPS) in rc10?  I realise that the IMU is already prioritised but can I adjust this even more?
    Is increasing EKF_POSNE_NOISE the best way to experiment with this or  EKF_VELD_NOISE?  (or should I increase both equally?)
    Currently my test machine flys well with 3.3.rc10 but I am trying to limit the movement in Poshold a bit more.  Attitude tracks very well with both AHRS and EKF, vibes are low and I have no real problems but a bit of wandering in GPS position hold modes when the GPS location changes suddenly.
      Alex,
      I think decreasing ACC_PNOISE may be best.  Increasing both EKF_POSNE_NOISE, EKF_VELD_NOISE together seems reasonable to me.
  • I have had now three times roll over / crash problem with the copter. Every time I go to test it, on the first attempt it will crash. I did complete reset for it, but didn't change the behavior. What could cause this? Any ideas? Obviously not really good "feature"..
    What happens on fist flight:
    arm, begin to add throttle. While still on the ground copter tries to lean left. I compensate with roll right and lift off succesfully. Craft flies nicely few second and then goes berserk. This time managed to ease the crash but was pretty much not possible to avoid. I picked up the copter on it's feet.
    second attempt:
    didn't boot after first one, straight arm. Lift off, still had to control it a bit on the lift off phase, but this time succesful flight and autotune. No problems at all.
    Log for latest flight:
    https://dl.dropboxusercontent.com/u/29992342/2015-09-09%2019-38-43.bin
    forgot: happened on different rc versions. rc10 in use this flight.
      VP,
      It looks like a failure of the front left motor (#5 because you're using a hexacopter in the plus configuration) to start properly.  It displays the classic signs of a motor failure, the actual roll/pitch separates from the desired suddenly and it rolls left in the direction of motors #3 and #5.  In addition the output sent to motor #5 goes to maximum while it's opposite (#6, back right) goes to minimum.
      It might not be a straight up motor failure but perhaps the motor needs to be calibrated or it's settings are different from the rest.
      • update: Motor was missing one magnet! So most likely problem solved. New motor it is.
      • Well, that was pretty accurate analyzis. Got the problem again, but this time better pids and no gimbal, I was able to control the thing and saw clearly that motor 5 was the problem, it almost stopped. Any idea what could cause motor malfunction? Magnets? bearing? esc? Motor or esc are not hot, maybe little warm only. Bearings doesn't seem that bad at least compared to others. These things seems quite hard to "debug"..
        Again, after that I was able to fly normally and did autotune. Tried to land in althold, landing was not recognized correctly and copter flipped.. Did read later posts about the same behavior. Hopefully landing will be tuned better in future.
        • VP, just curious. Were you able to control the Hex with one failing motor? Was it bad? How much thrust you need to hover?
