Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I had a hard landing yesterday after trying LAND mode for first time since AC3.3.1 , it went to land but it never slowed down the descent speed before touching down, literally slammed into the ground....I have my land speed set to 45cm/s.....
    log attached, anyone that can help out? I have been able to replicate the issue and even sent land speed to 30cm/s and it doesnt seem to make any difference
    2 log files attached...i think on the second one i aborted the landing by switching to stab
    2015-11-05 11-45-25.bin
    2015-11-05 11-48-05.bin
    • The copter does not slow to Land Speed until it believes it is 10m above Home Altitude. Your WPNAV_ACCEL_Z is set to 4.5 m/s.  At this speed, it would hit the ground in 2.2 seconds.  Your WPNAV_ACCEL_Z is set to 1.5 m/s/s.  It would take 2.7 seconds to decelerate to 0.45m/s from 4.5 m/s.  The copter did begin to slow and impacted the ground at about 2 m/s.
      So it appears everything functioned as it was programmed to.  I think the algorithm could be improved if it looked at the parameters to determine when it should begin to slow down, instead of using a 10m hard-coded setting.
      • Ooops, WPNAV_ACCEL_Z is set to 4.5m/s should be WPNAV_SPEED_DN = 4.5m/s
        • ok thanks yea I reduced WPNAV_SPEED_DN to 4.0m/s only and now it seems to be working ok, it slows down nicely at about 10meters and lands softly....thanks Rob
      • well I meant I should increase the accel_z and reduce the accel right?
      • thanks for looking into Rob!!...but it used to work just fine with these same parameters in 3.2.1, I dont recall crash landing like that....i do recall very well what you mention and it slowing down at 10m or so...but not now, at least visually, it doesnt seem to slow down at all...or doesnt try hard enough...
        should I decrease the WPNAV parameters both?
        • Another problem is that it appears to have impacted the ground while it thought it was at 2m still.  So obviously there was a height estimation error.
        • I would decreased the WPNAV_SPEED_DN, and increase the WPNAV_ACCEL_Z.  If you used 250 and 250, you'd have 2.5 m/s and 2.5 m/s/s.  At 2.5 m/s, you have 4 seconds from 10m to impact, but would only take 1 second to decelerate to zero.
          You can balance those off however you like.
          It is curious, when it passed 10m, it didn't even begin to try decelerating for 500 milliseconds (half a second).  I wonder if that's due to a jerk limiter?  By that point it was already at just 7.5m. So it had just 1.67 seconds to stop.
  • Hi
    I got this result after autotune on a X8, flys OK but values out of range or?
    3702120037?profile=original
    • After installing 3.3.1, I noticed a couple of PID values changed: RATE_RLL_IMAX & RATE_PIT_IMAX to 2000 from the earlier 1000 setting.  Did the PID loops change such that what was 1000 on 3.2.1 needs to be 2000 to behave the same on 3.3.1?
