Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • anyone have this??? http://www.hobbyking.com/hobbyking/store/__81874__PixFalcon_Micro_P...
    thoughts... settings etc etc.. mods youve done...??
    i have one flies pretty good.. getting alot of errors though mainly variances on the compass.. but ive removed the checking feature on that .. if i turn the copter by hand left and right it goes to a green light.. kinda weird... but thats indoors.. im going to try 3.3.2 rc 2 outside tomorrow.. i re set everything from compass rc transmitter even esc calibration.. to make sure im good..
    just wondering if anyone has it what you think etc..
    • T3
      Be careful with the built in buzzer. It may interfere with the Accels and the compass.
      I've got one but I've only put it through some bench tests, I've never actually flown it.  It seemed ok to me except it doesn't allow easy connection of the ground wire to the ESCs.  We recommend connecting the signal and ground wires for all ESC to the Pixhawk because without it the ESCs can be confused about the voltage coming across the signal wire which can lead to ESC reliability problems.
      • Altimeter, geo-reference, laser range-finder
        When a laser range-finder is used is it possible to use this altitude as the default for the geo-reference process.
        As I understand, currently laser-altimeter is not used for auto missions, and probably either barometric or GPS is used for geo-referencing.
    Hi Cala and Goran
    Thanks for that. So is rc2 considered safe and stable to use? Is there an expected release date?
      I was planning in pushing AC-3.3.2 as the default over the weekend but got caught up with the xracer so I'm just reviewing the support forum and this thread to ensure -rc2 hasn't caused anyone troubles.
      It's not too different from AC3.2.1 so I think it's generally safe to fly.
      • T3
        Randy,
        have you made any tests so far regarding the ICM-20608/MPU9250 and 4kHz sampling to eliminate the need for vibration isolation? ;-)
        Looking forward to AC 3.4 (3.5)!
          I haven't done any tests with the accels running at 4kHz but it keeps coming up in the discussion with Tridge and Paul Riseborough so I think it'll happen at some point in the next couple of months.  Both the XRacer and the NAVIO+ have this IMU and hopefully most manufacturers will move to this IMU sooner or later.
        • Are you referring to Linux rt AP like a Pi2 Navio+?  This would be nice to see.  Just got one : )
          • T3
            Shaun,
            I was referring to Randy's comment about the XRacer. It is the first autopilot of the new FMUv4 Pixhawk generation (see: https://pixhawk.org/modules/pixracer and http://www.auav.co/product-p/xr-v1.htm) and it is already (partly?) supported in the master branch. So it will be interesting interesting to follow the development.
            And since the Navio+ also has an 9250 on board...
