Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Man, that was close!
    • Battery failure or ESC maybe. Operator faults: no safety distance, no parachute... that is not the proper way to promote professional use...
      • its no ESC...it drops down like a rock,propellers still spinning...and ist X8 prone to esc failure
  • When connecting the SToRM32 gimbal controller via mavlink to the Pixhawk, getting parameters in MP doesn't work anymore. It just gets stuck on "getting params id 71". It is confirmed that more people have this issue. Firmware 0.89e, MP 1.3.33 and APM:C 3.3.2.
  • I solved my problem about the Landing Gear (=
    First at all: thank you very much to everyone!
    The problem was the following:
    Landing gear that opens on copter start up.
    Every time I plug the battery the landing gear open itself.
    The solution was the following:
    Use the Safety Switch.
    I had disabled the safety switch.
    With enabling it every problem was solved!
  • Hello, I almost crashed today as my copter went crazy in stabilize mode while trying to position to land. It began to drift hard and I had to steer fully against the drift to catch it again. After estimated 2 seconds, it was stable again and I was able to land luckily. There was almost no wind!
    I only see ERR EKF_CHECK in the log. Maybe you can help me find the cause.
    I really thought this is almost impossible when flying in stabilize.
    Here is the log, please have a look towards the end:
    https://www.dropbox.com/s/m7uyhq0grc9telx/2015-12-21%2017-06-54.bin...
    With the next battery, this issue also happened somewhere during the flight in greater altitude. After I noticed it, I switched to loiter, which caused the copter to go completely retard, giving full throttle while flying towards a certain direction. I catched it switching back to stabilize and landed.
    Here is the second log containing this:
    https://www.dropbox.com/s/2261m91jzg3rejf/2015-12-21%2017-25-45.bin...
    I had great luck not to crash today.
    I really want to know what is wrong with the Pix these days.
    I am flying a Hexa with AUAV-X2 board running Copter 3.3.2 stable.
    Sunnysky 980kv motors with 10x5 props, 30A escs, Drotek M8N XL GPS on 4s.
    Any help is appreciated.
    2015-12-21 17-06-54.bin
    Shared with Dropbox
    • You have bad vibrations. Pretty sure that's the cause. Look at clip0/clip1 - it's clipping all the time and your vibe values are very high. Everything in the EKF is struggling - even earlier on in the flight, its only at the end that things get bad enough to cause an issue.
      The thing I don't understand is the GyrX offset decreases rapidly at the end. Not sure if this is vibration related or not.
      I wouldn't fly in anything other than stabilize with things the way they are - loiter is really chancing it!
      • I also found that out now. But only in Z axis, am I right?
        My FC sits in a case and this is mounted on Hobbyking FC mounting foam pads. What can I do to reduce the vibrations further?
        I am wondering, why the copter almost crashed although I was flying in stabilize?
        Here are two screenshots from the flight where the loiter flyaway occured:
        3702729503?profile=originalI read in the Wiki, that if the EKF4.SV and SV value is above 1, the EKF stops using the GPS for calculating the position and the velocity.
        Now why did it do that? As you can see, I have perfect GPS reception (hdop ~0.7, sats 13+).
        Also the Mag failed for some unknown reason:
        3702729345?profile=originalShouldn't be caused by vibrations, I think.
        Same behavior with the stabilize flight:
        3702729494?profile=originalI don't understand why the copter behaved unstable despite flying in stabilize mode which has nothing to do with GPS?!
        Thanks for your help.
        • @Dave,
          I can help you with FFT analysis to discover resonant frequencies in your
          vibration patterns to discover real cause  behind the vibrations.
          Vibrations can be due to a number of parallel control data streams interacting each to other.
          My fellow student lost his hearing, working as mainframe computer operator due to infrasounds generated by collective sound frequencies by individual mainframe colling system fans, damaging his inner ear mechanics.
          So higher harmonics present in such sophisticated electronic gearbox -
          processor's clock, PWM clock, flight controlle's clock, GPS clock ( 1Hz, 4Hz or 10 Hz), motor's RPM clock can make such to start generating much lower, infrasonic vibrations ( 1Hz - 30 Hz),
          my next guess is moisture build up on platine connectors if you fly at higher altitude for a longer time
          to keep stabilize mode to stabilize instabilities (see above) may eat up
          100% processor power, make 100% memory busy,
          so I would suggest to let Ardu fly your drone in debug mode and have
          processor busy, memory free parameters downloaded via MAVLINK to your control station via telemetry.
          darius
          manta103g@gmail.com
          • Thanks for your answer.
            So what to do now to get the data for the FFT? Also, I think this would need a much higher sampling rate, doesn't it? I think its 50Hz standard, which is too low for high frequency vibes.
