Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Yesterday my Hex (with PixHawk fc on AC V3.3.3) crashed.
Luckily, there was not much damage. One prop and I lost one of the dampening balls of my gimbal.
The hex was in POS_HOLD and I was decending slowly by lowering my throttle stick.
When it hit the ground geltly, I switched to Stablyze (throttle stick in lowest position)
Then after a split of a second the motor on the right (#1) went full speed and flipped the Hex upside down, breaking a prop and throwing the gimbal away.
When I picked up the hex, one motor (the one that flipped the hex) was still running rather fast.
After a second or so the motor stopped. I guess because the PixHawk disarmed the system.
Can somebody look at my log please. Perhaps he can find the cause of my crash.
1 6-4-2016 9-17-50 PM (crash).bin.rar
Yes, can see that you switch to stabilize mode and that all motors were shutdown. Shortly there after I can see a huge spike in current indicating something started up again. Looks like possibly an ESC hickup.
"ESC hickup"
So You're saying this could happen randomly to anyone, anytime?
Never heard of it either.
In the log I can also see that there is a huge spike at the end on motor #1.
But..............what is the cause if this spike?
I don't want this to happen at 50 meters high!
I see what Michael says which is a current spike even though the output to the motors is zero. To be clear, that ESC hickup would need to be an issue within the ESC itself or possibly a very low level hardware (i.e. a power spike is somehow getting into the Pixhawk) or software problem on the Pixhawk. Ardupilot is requesting zero outputs be sent to all the motors so it's not a high level software problem.
Thanks Randy for investigating my problem,
It's a bit hard for me to understand your explanation(s), because I'm not a programmer .(just a fanatic diy man)
As far as I can follow you:
Is it most likely the esc itself that's causing the spike?
Do you have any advice in this matter?
BTW: the esc's I'm using are "Spider 30A OPTO 2-6 lipo 600Hz"
It could be one of so many things.. It could be an FPV radio or other radio that has been placed close to the ESC signal wires. I've definitely seen cases where a servo gets upset and begins shaking when it placed near a 3DR radio. The power of an FPV radio system is much higher. I haven't heard of this affecting ESCs before but it's possible.
From looking at the logs the main flight controller's voltage drops by 0.3V at the same time as the current spikes. It happens earlier in the log as well. That's a bit odd, could there be a high powered radio (like an RFD900) or some other sensor (Lidar perhaps) that's pulling power directly from the pixhawk? If "yes" then powering that device from a BEC might help.
Wow Randy, I'm learning a lot here......
Never to old (67) to learn, lol.
The Pixhawk is powered by a seperate bec (not by esc)
The Pixhawk is supplying power to only the FrSky RX and a 433 mHz module (for using Tower app).
The 433MHz 100mW module is rather close to the "failing" esc and the antenna is only 3 cm from the esc. So I will unplug it for the time being.
So no such thing as RFD900 and/or Lidar.
1 GPS, external compass and external led are also powered by the Pixhawk.
I have also an extra VCC and GND wire from the bec to AUX 4 of the Pixhawk. So not only a power line to "the "power"plug on the Pixhawk, but also power wires to the AUX 4.
Could this give problems?
AND also a powerline (vcc, gnd) to AUX 5 on the Pixhawk for powering my landing gear. It's only working temporarily for retracting and deploying, but could this be an issue?
Paul, yes, I think it's the ESC or some other power related issue on the vehicle. There are many things that could cause a spike on the pwm signal pin .. for example, are the ground wires from the ESC connected to the pixhawk's top rail (on the back of the pixhawk)? The issue is very unlikely to be in the ArduPilot software.
"for example, are the ground wires from the ESC connected to the pixhawk's top rail"
Randy, I have all the esc GND wires at the top of the Pixhawk and the signal wires at the bottom.
I sense that you have more options for this problem.
Can you please suggest some more possibilities?
1
2
3
4
5
of 449 Next
