Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • I've had dozens of flights on  3.4 [ That I loaded in December ] no problems at all. I armed with it in my hand and launched from my boat it works great!! :] However I flew last night and had verbal error piped out on my Taranis. EKF error or variance I forget which it said.  I would not have known otherwise seemed to fly just fine after. Not worried about it really. But it is interesting it was VERY cold when I flew. 15 degrees or so. I've heard of people having that issue. Anyway if interested here's several 3.4 logs and one with the error.
    https://drive.google.com/drive/folders/0B3MgBBZGOf88TzBUcWhoLTFrRFk
    3.4 logs - Google Drive
  • Hi, had a crash/hard landing with version 3.3.2. The quad was flying quite nicely until the battery failsafe kicked in and the quad quickly became unstable and went down wobbling hard. The quad was below the configured RTL altitude at the time of the failsafe event. The log shows that the throttle output saturates and the angles don't follow command when failsafe begins. Can anyone here see the cause of the problem? Here's the Log
    2016-02-10 17-24-05.bin
    • your battery couldnt handle the current it takes to climb in the initial stages of rtl. It looks like you are using a very low c rated battery, and it was dead by the time RTL kicked in. Set your voltage failsafe higher to avoid this in the future.
      • Thanks Craig, I was indeed using a low c rated battery. Turnigy Multistar 10c 8Ah to be exact.
  • Hi Randy and friends
    Is it possible to change the height at which copter transitions from RTL to land .. I know you can set the land height to 0 for Land and RTL to a height to return at, but it is the section where it pauses to enter landing mode. I would like to change this height but I don't see any setting in MP for it. Is it possible?
    thanks
      So you're talking about the altitude at which it slows from the WPNAV_SPEED_DN (normally 1.5m/s) to LAND_SPEED (normally 0.5m/s).  I'm afraid the altitude is hard-coded to 10m above home unless the vehicle has a sonar in which case it will slow at the higher of 10m or when it first detects something below.  We could add a parameter for Copter-3.4 perhaps.  Just to understand the use case, I guess you would like to make it lower so it gets down faster?
      • Hi Randy !
        Well, I would like to increase the transition zone to say 14m as its a very heavy large copter and when it descends its struggles to slow enough at the land zone height and we have one hard landing already .. I know I can set the WP Down speed but if i make it slower when it comes down from 200m its a long time for the descent .. so I have increased the WP Down speed and now need to raise the land section  from 10m hard coded to approx 14m.. unsure until its tested.
        cheers
          Reuben,
          Did that incident happen with a version before Copter-3.3.2?  In 3.3.2 we fixed an issue with how the landings were being done that should stop it from having the hard landings (see release notes here).
          • Yes Randy pre 3.3.2 on this machine we are still running the old version..I think it still on 3.2.1 :)  It was landing fine..infact we have done so many missions with this unit with no issue .. but it is a bit heavier now and i did increase the WP NAV down speed.. so it did no take so long to lose altitude after clearing some high terrain and enter its Land stage. Now it surpasses the safe height due to increased acceleration..Kinda drops like a stone and does not have enough time to pull up. and yes the copter has heaps of power and hovers around 450
              Reuben,
              Ok, so if you could give Copter-3.3.2 a try and see if it still has the problem that'd be good.  If it does still have the problem, just post a dataflash log and we can have a look.
