Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
I have a couple of issues which I can't figure out.
1. At the field the last couple of times I have not been able to get a 3D GPS fix at all. HDOP stays at 99. Now I'm in my office and I'm getting a 3D fix inside easily, which seems crazy. The only differences are I just upgraded to 3.3.3 from 3.3.2rc, it's warmer in my office than outside (by about 20o) and I am on USB power rather than battery. can't really see how any of these would translate into GPS no workee. Any ideas? It's not a connection issue in case anyone wants to suggest that :)
2. I have calibrated the accelerometers multiple times but I end up with a corner drooping in flight and the copter drifting a lot in AltHold. Could this be temp related? How flat does the mounting of the FC have to be relative to the frame? I would have thought that the calibration and leveling would take care of any discrepencies, but does it?
AUAV-X2 if it matters.
Andy, I see similar things, were it boots up fine, but will not lock GPS until I unplug it and start over. Then it works fine. Have you tried that? As for the leveling, that is done when you arm it. Whatever angle it is when you arm is what it considers level. Calibration, it seems is affected by the temp. I was having problems with accel and magnetometer cals and it was suggested that I cal in the cold. That seems to help, though it isn't as cold out now. Hope that helps.
I tried many reboots and change of batteries - same result. It definitely coincided with my upgrade to 3.3.2rc, but now is gone again. I guess I'll have more concrete proof if its now fine at the field.
I'd be surprised if level was set at arming - that can't be level at all!
of course level is not set on arming....
Hi everybody. I happened to install the Copter 3.3.3 on my Octa-Quad where I was flying the 3.4-dev of January 27th. The system turned to have a poor heading hold (oscillations of even 20 deg) and a poor position hold. I thought It might be due to a magnetometer calibration (as I moved the GPS on the back), so I calibrate it again, but same behaviour. In order to stop the oscillations in LOITER I had to increase the POS_XY_P from 1.5 to 2.5... Is there any major changes that are influencing that behavior?
I am about to upload the previous firmware and to make other flying test, maybe I could upload a set of telemetry that might be helpful for finding any possible issue
This is a capture of the Heading vs Desired Heading. It happen to get worst in Guided mode
If it's a heading hold problem then adjusting the yaw parameters is more likely to help. So for example, on the Extended Tuning screen (of mission planner), the Stabilize Yaw, and Rate Yaw parameters.
The compass's effect on the heading is quite slow, it's really most the Z-axis gyro that controls the heading so it makes sense that re-calibrating the compass didn't help much.
Hello,
Anyone know what .cpp file has the hard coded rate P limits? Or is this done in Missionplanner? Looking to try lowering the p limit to .06
Derek,
The limits are enforced by the mission planner but only on the extended tuning screen. If you adjust them using the full parameter list (or full parameter tree) screen then it's possible to set them to whatever you like.
Flew my TBS Discovery with AC3.3.3, so far, it's stable :)
