Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
            • Perfect, what are the parameter changes needed?
              RB
      Have you the logs of the second issue?
      • I will upload the logs later today. I have one more question... Can I assign another channel other than 7 to trigger the camera? I actually want to trigger 2 cameras. 1 on channel 7 and one on channel 9-12. I recieved a stratosnapper that does not work. And do not have time to wait for another one.
        Thanks again.
          Craig,
          We only support triggering a single camera at the moment.  I've created an enhancement request here but I can't promise when we will implement it.  You're actually the second person that I've heard ask for this (although the other person wanted both cameras to take pictures at the same time).
  • Oooh, Alexmos support...to do what exactly?
    • Hi,
      i tried to find some wiki pages about this... ...no chance...
      Is there just no wiki page, or did i just not find it? ;)
      Thanks  a lot!!!
        Johannes,
        There's no wiki page for the alexmos setup yet I'm afraid although it's on the to-do list.
        • Hi Randy!
          I have searched the various sources and cannot find anything conclusive on alexmos/basecam support, especially the serial capability. Does this use the UART on the SimpleBGC otherwise intended for a bluetooth module, or something else? Or was this abandoned for StoRM32-only support?
          If you can give me some direction I am happy to help update the documentation, as I strongly suspect others are wondering the same to do some Points of Interest.
          Cheers.
    • I have an older version of Alexmos board. On previous firmware, it was working fine with PWM RC input. The board is connected to pixhawks Aux1 and configured through the gimbal settings in mission planner. In AC3.3rc1, the same setup fails to work. I think it is related to the feature of the firmware that supports Alexmos boards through the serial interface. But my Alexmos board is not capable of Serial controls. The only way that made my setup work is by directly connecting the RC in of the Alexmos board to the receiver module thus allowing it to work with PWM.
      Euan,
      At the moment, it simply sends angle demands to the gimbal via a serial interface (we need a wiki to describe how to connect the serial cable and also not all alexmos gimbal control boards expose the requierd pins).  In the first stage it's not too different from using a pwm interface although the setup should be easier.  This release also adds support for the do-mount-control mission item so besides ROI, a camera can be pointed to specific angles as part of a mission.
