Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Looks really nice :-)
Can you attach a log please? I'd like to look at the settings, PWM signals, etc.
Lijingwei,
One thing we haven't mentioned on that wiki page is that an external BEC is required to power the servos. So the Pixhawk does not power the rear servo rail on it's own.
Pomaroli,
There's a lost-copter alarm that will sound if it's attached to an aux switch (aka ch7/ch8 switch) and there's also a special transmitter stick move which is: right stick down and right, left stick down.
The Lost copter alarm works really well. Tested is a couple of days ago and it's nice to be able to let it beeb once or continue to beep as long as the stick is held down / right
1:10 in the video
Hi VP Kuisma, and all
I'd did it, and same as you.
That i can see by trying the Copter 3.3rc4,serial 4: 57k protocol 1,(full parameter tree)
it's that with the Storm32V0.76x, i have in TM MP two quad, on one the right place and one 0°N, 0°W!?
and when the teensy or Tower had the mavlink flow, mode change continuously from stab to rtl (or unknow for Tower) but not by TM and MP?!
Maybe due to the new bridge for th Strom32 by the MP telemetry, or something like that...
i'm waiting for the Betacopter V3.3Rc4 by OlliW, wait and see...
Gregor,
I'll make a wiki page to describe how to assign the serial ports but basically it involves modifying the SERIALX_PROTOCOL parameters where X is a number from 1 ~4 so no need to modify the SRX_ parameters I think.
Hi, I'm currently trying to get 3.3b working on PX4+IO.
Currently I've gathered a couple of questions:
/!\ IMPORTANT /!\ Dear devs who are in contact with Pixhawk webmasters, please add note here (http://copter.ardupilot.com/wiki/common-load-firmware-px4/#load_fir...) that TO FLASH PX4IO YOU HAVE TO UNPLUG PX4FLOW!!!11oneone. I upgraded PX4IO many times and still sometimes you just follow the instruction which sometimes results misunderstandings.
Thanks in advance.
Ok. digging process on MK-BL ESCs goes on.
For now there is new information:
1. To enable autorun of mkblctrl driver on arduCopter you have to create file /etc/APM/mkblctrl with correct motor numbering.
Does anybody know what "correct motor numbering" means in terms of syntax or usage example?
2. Found this config here. It moves me one tiny step forward on understanding how does it work inside.
I guess I need dev's help after all. I found 'mkblctrl' in code here and I found mkblctrl driver, but I can't really figure out at which moment driver loads config from file and what options are needed.
394
395
396
397
398
of 449 Next
