Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Dennis,
I'm not able to open the log in Mission Planner or APPlanner2. I think there may be an issue with the log file. Perhaps clear the logs completely and do the test again or maybe take out the SD card from pixhawk and plug it into your PC and copy the file directly to your machine instead of downloading over mavlink (which can be very slow).
Dennis,
For sure it depends on your location, but 10min and even 3min sound too high. In Germany it is always < 1min with an M8N - no matter is AC3.2.1 or AC3.3. So maybe something is wrong with your module?!
...outside...
Dennis,
Thanks for the report. Any idea which settings are being changed that cause the slower lock time? Would it be possible to run back-to-back tests with AC3.2.1 and AC3.3 with the Log Bitmask set to "Log while disarmed" so we can see the difference?
Sorry to be annoying but we have seen this type of report with releases in the past and often it's comes down to environmental factors that happened at the time of the firmware upgrade. Still, that may not be the case this time so if you have some more info that would help.
By the way, AC3.3 allows controlling some settings of the GPS using these parameters:
i ran 3.3rc7 for 20 flights or so and also with an M8N and didnt experience any of the issues that Dennis is seeing....I actually ran with two GPS, M8N as primary and 6H as secondary
may have found an anomaly using RC 7 in GUIDED mode:
When radio is off, everything works okay.
When radio is on (flight mode switch set to GUIDED also) motors start spinning fast when arming through mavros. My RC has throttle to medium as default, so tried pushing throttle to zero. This actually made motors spin even faster. Logs show RCin as steadily climbing when RC is on, and as zero when RC is off.
Weird.
Heddn,
If you have dataflash logs that'd be great. The pilot's inputs should be completely ignored in Guided mode with the exception of the yaw input so it does sound very strange indeed.
One of the logs got very big, so I put them on onedrive: http://1drv.ms/1IjN5BT
15-07-19_22-53-52.bin : RC off, everything ok
15-07-19_22-20-16.bin: RC on, bananas mode.
Also I got a lot of "EKF variance too high" prior to testing, so turned this feature off. Might not be related. (And this was indoor with poor GPS performance, so that might explain that error).
Also, APM plannner v2 won't show logs due to them not having "US time", but displays fine in Mission Planner.
I tried to build 3.3 for flymaple but I got a compiler error.
HAL_CPU_CLASS for this board is HAL_CPU_CLASS_75, but a condition for using NavEKF (in AP_AHRS_NavEKF.h) is:
#if HAL_CPU_CLASS >= HAL_CPU_CLASS_150
The rest of the code assumes that EKF is in use and doesn't have any way of handling if it isn't. Is the 75MHz CPU on the flymaple (STM32f103RE) capable of running the EKF?
Running at half the clock rate and no FPU puts it an significant performance disadvantage. I don't know if that is too slow, that's a questions for the devs. Maybe there is an easy way to test. Force a compile and then be able to monitor late loop executions.
