Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
With RC5 I now get the error message "Error EKF POS VERT AGL" all the time. The quad (550 H Frame) flies fine in loiter, position, stabilize.
Steve
thanks pal for the feedback. It seems that this error does not affect the quad. though when using the Mission Planner, this error prompt is quite annoying :D hopefully this will get fix soon. thanks again!
I'm using MP1.3.27 build 1.1.5620.38044 and updated to rc5 and after that I did a "reset to defaults".
I choosed frame and then I tried to calibrate accel, the program steps from place level to left and then directly to right?
So I am unable to do the calibration...
I have uninstalled MP and reinstalled it and the same with the FW but with the same result?
I'm getting the same, did you manage to figure out the root cause yet?
Seems to be fixed in rc6
I tried with 3.2.1 and then the calibration of accel was OK so it seems to be rc5, rc4 was OK.
I'm also using Mission Planner is 1.3.27 build 1.1.5620.38044
I get EKF PRED POS HORIZ ABS when I power up but changes to "Error EKF POS VERT AGL when i get a satellite lock
8 satellite hdop 1.8
I have just flown and everything seems to be working ok, tried loiter but not RTL
thanks for the feedback. I stll haven't flow yet because I am still getting more feedback about these errors. Hopefully such errors wont affect the flights, it would be troublesome if it would cause a fatal crash..
I just loaded 3.3-rc5 and I'm getting "Error EKF POS VERT AGL" continously
i got that error before I update to the latest beta firmware of Mission Planner. But now the error prompt just changed to EKF PRED POS HORIZ ABS. THe quad arms with no probs. But I am a bit concern with these EKF errors..
the version of my Mission Planner is 1.3.27 build 1.1.5620.38044
