Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Altitude Jump during AUTO mission.
On RC8, fully tuned including Yaw without any alteration afterwards (perfect feel, no twitching in Pitch), the drone is pretty stable and has had a number of flights in the Netherlands, without the strange jumpyness in Loiter, I experienced recently at my holiday location in France...
After taking off in Loiter with a fast flashing green indicator, and a HDOP lower as 0.90, I took this heavy drone to approx 10m, when I noticed already a not so steady Loiter as usual (motor sound not monotone, but quickly ramping up, down, while maintaining altitude...
Never heard that before in loiter....(as If GPS height position was not constant, and EKF was not smoothing it out)
Then switching to Auto mode for a 900m traject, at 20m Altitude, so drone started gaining altitude to get to 20 meters at first waypoint...and everything was still fine...
Then around the second waypoint it just shoots up into the sky full throttle, climbing quickly to approx 40m, after which it stabilized by itself, but didn't get lower to the original programmed 20m for the trip, so switched out of the Auto mode and brought it back in Loiter, where it remained very rough on the engines... i.e. sounding like ramping up and down rather quickly every now and then (as if it was planning to Shoot up again..)
So after it getting on the ground, it flipped (no harm done), I investigated the log, looking for the obvious like GPS Glitch or Baro problems, either one failing or whatever, but none of the above... (No EKF failures, and before shooting up limited VIBE in X, Y, and Z axis..)
Log at: https://drive.google.com/file/d/0BwKkz56PHqS0RE02VnJXaWc2RW8/view?u...
I am completely stunned as what happend here.., ???
There is a marked increase in vibrations at the time this happened (particuarly on the Z axis) so I wonder whether something mechanical was at the root (apart from the overall bad vibrations that Randy mentioned).
You also have a Gyro dropout in IMU2 earlier on, I've not seen this before.
If you look at EKF4->SV you will see it jump above 2 which means that the vertical inconsistency got so bad that it stopped using the GPS. However EKF4->SH (the baro vert inconsistency) shows the same thing, so it seems more likely that the vibrations caused the inconsistency. Note too that the IMU clipping goes up at the same time, so I think probably you have some kind of cascading effect.
according to what I have read in the EKF settings, you may increase the importance of the GPS over the Baro alt correct ?
Could that be preventing it, if nothing obvious can be found in the hardware section... I do use vibration damping which is more solid than the original 3D damping, so I may need to go back to this softer stuff...
Currently the PixHawk is close to hard bolted to the frame..
Thanks again !
Looks like high vibration levels. Hopefully we will have some real-time display of this in the ground stations in the near future. For now it's only visible in the dataflash logs but they are very clearly too high.
I am however wondering why as the same platform has been flying fine for quite some time, i.e from 3.21 onwards....
At the first part of the flight when I still was in loiter the vibes are fine, it's as soon as it is gaing height in Auto it starts, but isn't this obvious as you are moving up fast ?
I.e are we looking at the result of the movement here ?
Erik,
The vibration levels are really quite high even at the beginning. The AC3.2.1 vs AC3.3 resistance to vibration is a good question - so the biggest difference from AC321 vs AC33 is we've replaced the 2nd-order-complementary-filter (aka InertialNav) with the EKF. We were expecting that that would improve resistance to vibration but in fact, it may not. It may even be worse which would be a bit of a sad result. PaulR (creator of the EKF) has started on the "New Maths" which is a large-ish change to improve EKF's robustness (i.e. bad vibes, bad sensor data) but that won't come until AC34.
AC33-rc9 will have one final change directly related to the EKF's vibration resistance, it's going to do a better job of picking the IMU with lower noise. Hopefully that will help.
Don't get me wrong I do like the progress a.k.a EKF, but I do see rather inconsistent behaviour between flights..., in RC7 I had clipping up too 3000 and higher, without any strange side effect...
I have never seen any EKF errors in my logs...
Suddenly now I get up to 100 (VIBS) and it is acting like it may jump up and down anytime... which I do not understand.., as the hardware didn't change at all.
I'll also do a compare between Params RC7 and RC8 to see what did change between both versions after initial download, maybe something has changed there ?
In my second flight yesterday I did reduce VEL_Z_P from 5 to 3 and in AltHold it was holding altitude a little better I.e without the engine variance in sound..., not sure if that can be related to this or not, but it was flying smoother as before...
I agree with what Andy says of course.
I'll also add that -rc8 had an attempt at improving the EKF's ability to deal with high vibration by pick the IMU that was clipping less. We've found that didn't improve resistance to high vibrations though (as we saw from Evgeny's on-going problems) so -rc9 will use a different method which checks the noise on each IMU instead of the level of clipping.
218
219
220
221
222
of 449 Next
