Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • Hi,  this has likely nothing to do with 3.3 and is better discussed in the telemetry threads or with the vendor you bought it from.
      • I would generally agree except the problem only arose after updating to 3.3. And when I change the SR params to correct the issue in 3.3 the params revert back to what doesn't work after a few power cycles. I have no idea what the issue is... hopefully it has nothing to do with 3.3.
        • Aargh stupid forum software.   Let's try again.
          The SR parameters are set by any device plugged into a serial / telemetry port that issues a stream request over Mavlink.   This will override whatever you try to set them at.
          • AHHHHHHHHH so does this mean the FW on my Teesny board could be the culprit??
            • Almost certainly!
  • on 3.3 rc12 im getting inconsistent compases as an error with a yellow light on my pixfalcon anyone have any ideas?
    i made sure to turn off the internal one and use the external in mp.. so im going to go back to 3.2.1 till this is offically released unless anyone has ideads?
    • You don't say when or where - on USB power or battery power? In your office or in the field?
      Most likely a hardware problem with your pixfalcon. Even though you are using the external the internal is still checked for consistency. What offsets does the internal give you? Does the output in the MP calibration screen look truly spherical?
      It also could be a problem with compass MOT - are you using this?
    • well i set it in full params to 1 which is external... and re did everything calibrations still does it...
      so i just went back to 3.2.1 and ill stay there till the officail is released
        James,
        Is there a dataflash log file somewhere?
      • just flew in a bit of wind.. on 3.2.1 i had no issues stock params pids ..on a zmr 250 frame... i just used 42hz instead of the default.. drifts slightly to the left.. maybe because of the wind.. but omg my heart was racing.. used a 20 c 1300mah zippy batt 10 bucks on hobby-king got about 4 min before it gave me my warning..
        3.3 is just too buggy now..... im using the micro pixhawk from hobby-king https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct...
        with the apm micro sensors.... no issues once i switched back with the  compass issue..... even after i choose which one.. from what i understand the pix picks the external one if its attached automatically but i had to manually go into mp and choose 1 which is external.. then i 3.3 rc12 all the issues arose on a clear day too.. everything calibrated...  now my external gps takes a long time to lock on..
        when i use my 450 quad with apm 2.6 its almost instantaneous ..
        maybe because its a official one and hobby king uses Chinese clones i dont know.. but once i switched back flew great.. alot of up and down and a little drift to the left.. but with 10 mph winds maybe thats normal.. held  loiter fine..
        with all my money invested around 500 dollars on this little 250 quad i was sooo nervous lol..
        the cool thing i didnt have to touch the pids then again i was only hovering and in a small back yard... but pretty stable
        heres some pics of my setup..
        1806 motors.. Chinese qav250 frame.
        12 amp afro esc's
        micro pixhawk with gps and pd board
        3 blade 5x3 props
        spectrum 6210 receiver with satellite
        dx8 radio
        3dprinted parts for cell phone holder
        telemetry kit
        galaxy s4 phone as tablet
        ppm encoder
