Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Copter-3.3.1 is out as the official release now. Thanks for the confirmation from Miroslav, Yssaril, RandyB, JoeG, Stephan and perhaps a couple of others that -rc1 seemed ok!
OK that was strange.
More on the 3.3.1 accel[1] not healthy messages
So trying to figure out what was going on. I decided to clear my logs, then try again.
I did the following:
I turned on my RC transmitter (It was not turned on previously)
I cleared the logs in the PixHawk.
I waited a while, then rebooted the PixHawk.
It seemed to complain about compass and other issues. So I re-calibrated the compass (at my desk, probably not best, but I decided to do it).
I then re-ran the Accelerometer calibration, this time it walked through the '"place on left side, place on right side, etc."
I even tried to arm (no flight battery) and then disarm. It all seemed to go ok.
I had a lot of 'bad AHRS' messages, and the HUD in Mission Planner seemed wonky, it was showing the copter on its side, but it was level.
So I rebooted the PixHawk, now the HUD shows level.
AND NO more errors or warnings.
Again, this is all while powering the pixhawk with my USB cable, no flight battery.
So, am I ok now? What other tests should I make before trying to fly?
Attached is my logfile, just in case anyone is asking.
I guess no one seems concerned, I deleted my logfile.
Hard to say what happened but the accel[1] not healthy indicates a (perhaps temporary) hardware failure of one of the two IMUs (the LSM303d to be precise). I'm not sure what we could do about that. In Copter-3.3 it's possible to disable an IMU completely (INS_USE, INS_USE2 parameters) but it's not recommended really. Better to replace the board if one IMU is failing regularly.
Is this because it can't read values from the IMU? I get this also from time to time with my AUAV-X2. Usually disconnecting / reconnecting the battery cures it but it would be nice to know why it happens.
Yes, it's likely that it's not responding to requests. I'm more of a software person but perhaps it could be because the power is not coming up quickly enough or the board voltage is too low (i.e. if USB power cable or PC it's attached to can't provide enough power so voltage sags). It could be a bad solder joint on the connection somewhere.
Thanks for the hints. I'll try this again with my flight battery. But other tests with the USB cable seem to be ok now.
I've powered it up from the same USB cable a few times now and I haven't been able to repeat the issue.
I can't say that it's gone forever, but at least I don't seem to have a hard permanent failure.
Thanks for all the Dev's work on the new release.
So I previously was using 3.2.1 and it was working.
I now loaded 3.3.1 on my PixHawk on my desk, only using my USB cable for the power to the PixHawk (as I have often done).
The firmware flash seemed to go ok. I power cycled.
I keep getting errors that I don't remember seeing before:
PreArm: Accelerometers not healthy
So I went to do the Initial setup, and tried the Accelerometer calibration.
Then I get this error:
Place vehicle level and press any key.
Initialising APM...
Initialising APM...
Calibration FAILED
Ok, what do I do? Why do I get an accel[1] not healthy? I can't remember ever seeing this before.
Or, MUST I test this with a flight battery, and not only powering the PixHawk with my USB cable?
Thanks for any hints!
An observation.
Yesterday I tried Auto Tune. The copter would not hold altitude while in Alt Hold, which is commonly reported by many. The AT was aborted and I discovered the vibration levels had worsened.
Today after improving the vibration levels by > one order of magnitude, during AT the copter held altitude much better.
Confirmation bias or a connection?
DG,
Great that you got the vibes reduced that much.
Bad vibrations will certainly affect AltHold performance. It's absolutely critical and we recommend people designing/building copters to check their vibration levels (see First Flight section's Measuring Vibration wiki page) and the live vibration monitor added in Copter-3.3 was added to try and make doing this a little easier.
