Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Many thank's Randy, here is the last one, The problem was at begining with autotune switch engaged by accident (distraction), I take off and copter become uncontrolable.
https://www.dropbox.com/sh/j4yvrd4zj9tk7yg/AAC7om2GayyPMJ5EGOZ-1nfY...
Hi folks,
I'm new to this community and I must say great work done my many here, thank you.
Quick question. I just upgraded from 3.2.1 to 3.3. How do I turn off the low voltage audible alarm while my Pixhawk is powered by USB without having to set FS_BAT_VOLTAGE to zero then remembering again before flying. It didn't do it in 3.2.1. Voltage does read correctly on the HUD so I don't need to calibrate the device.
Thanks,
Bob
Never mind. Found a failing USB power supply. Once changed the Pixhawk is now operating as it should, and did,at the correct USB voltage and alarm silent.
The accel readings for the Z axis show considerably higher amplitude on IMU2. It appears the difference is noise / vibration on IMU2. as average amplitudes seem close. But vibration on IMU2 appears factors above IMU1.
The vibration show very low readings on X and Y and higher as expected readings on Z. On higher motor output / acceleration IMU 2 appears to be clipped whereas I would suspect IMU 1 would be fine.
Looking at the board layout the LMS is out at the corner of the board where I would guess it is seeing some board vibration.
Is this vibration difference IMU2 being higher a consistent difference typically seen? Has anyone attempted adding some vibration reduction foam to support the board corner to reduce this?
The copter seems to be handling well even during acceleration but I am concerned around the clipping seen. This was a 15 minute flight and I am not sure if this number of clips is a serious issue. Obviously 0 is best. No issues with Alt Hold very stable on altitude while flying.
I have done a few of revisions on vibration control and reduced the aount of z vibration and clipping events significantly but may have to do more.
Joe,
I think we generally see the lsm303d being noisier than them mpu6k but not to the extent shown in these logs.
The two sensors run at different frequencies (mpu6k is 1000Hz, LSM303d is 1600Hz) so I guess it could be very high frequency vibration that's being aliased down to the 400hz main loop rate (we average the received sensor values at 400hz)... or maybe you're right that it's the sensor's position on the board. I've certainly heard a PCB can acting like a trampoline due to vibration (apparently 3DR hit this problem during the development of the Solo).
I think the vibe levels you're seeing are borderline ok. 200 or 250 clipping events is not many really but it does indicate that the vibes are close enough that they occasionally go out of range. My IRIS for example always has zero clipping events unless I really bang it into the ground on a hard landing (like here).
Randy,
I went ahead and made a custom anti-vibration mount for the Pixhawk as well as did some reduction in the servo wire leads by removing redundant grounds etc.
The clipping was happening during high motor output and I was concerned that in a situation where continuous high output might be required that flight performance and stability might be affected or even if a prop was imbalanced.
Results after installation are dramatically lower.
Comparing IMU 1 and 2 there now is very close agreement between the two on the z axis.
There are now zero clipping events even with hard vertical accelerations.
Nice vibration levels, but I'm afraid removing gnd wires from ESCs on pixhawk is a recepy for disaster due to known sync loss issues especially with low kv high voltage, high pole count motors + SK/blheli ESCs.
I am not using SK or BLHeli in this copter. I m using Castle ESC with their multirotor software.
I have never had any sync issues with these. Have used the Castles on many multicopters and low
KV heli motors. I have had a couple of cases with SK sync issue on high pole count pancake motors and am careful on firmware revisions on these. However for higher end builds with expensive payloads tend to rely on the Castles.
Castle are well known for quality they also tend to be rather expensive. Since July I use HW xRotor40a-Pro, with breaking enabled they are as as fast as spiders 40a flashed with blheli on low kv otors, but barelly get warm.
Ah, I didn't notice that change. I've heard this same info from Rob Lefebvre.
