Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • That's mean if the copter decides to Land for failsafe and you switch to another mode the copter abort land and fly in that mode?
          Cala,
          Yes, that's right.  It pretty much never ignores the pilot's requests to change the flight mode unless it's impossible to enter that flight mode due to poor GPS.
          • the copter responds to switching to stabilize in overriding the Landing sequence now if i use the flight mode switch on taranis. but when i use a toggle switch which i programmed to override the ch5 pwm, it does not work.. no switching from landing to stabilize. at least now i can confirm that the overriding still works
          • Thank's
  • I was doing some test flying the other day to check out the Do_mount_ command.  It flew very well both in Auto and Loiter.  I landed and switched out the battery.  On restart I got the dreaded 'Inconsistent compasses" message.  Restarted several times with no change.
    What could have caused this?  This is the first time time in over a year of flying this setup that I have seen this.
    Do I recalibrate  and move on hoping it doesn't repeat?  Any field fix?
    • So this is supposed to only happen when the compasses disagree by a large margin. This happens to me when both compasses get uneven interference - either because MOTCT is inappropriately applied (because my power module gives bogus readings on USB power) or when I mount my battery with the lead "exit" end close to the compass (which surprisingly generates large amounts of interference). Not sure if either of these is your problem, but I'll throw it out there anyway :)
      • I have the same issue with the incorrect PM reading when USB is connected.  It does not affect the in flight reading as long as calibration is done after arming the safety switch but I think this may be causing some users problems since they may not be aware of the issue and calibrate using USB in the preferably disarmed state.  I have seen several reports not of this other than my own so I think this is a consistent issue.  Will put in bug report.
      • The compass will definitely be affected by a main battery power lead passing close to it.  This will generate a magnetic field whenever there is current and the close proximity will affect the field around the compass.  Small differences in placement of the wires could cause varied magnetic disturbances which the compass MOT calibration for current effects would not be able to account for.  The magnetic field variation versus current needs to be a fixed curve and the varying placement of the wire in close proximity to the compass would probably produce a different effect each time you put a battery on.
      • Randy and Andy,
        I have launched form this site many times with no previous issue and none on the first flight.
        Thanks for the replies.  I did try both moving and rotating with no change after disconnecting and reconnecting the battery several times.
        The battery mounting has not changed in the year I have been flying this build.
        I guess I will try a re-calibration and then the disable internal if that doesn't work.
        Would still like to understand why the change in a 10 minute period at the same site with no other changes.
      Greg,
      The interference could be because of some interference at the launch site (like a metal pipe in the ground) so you could try moving the copter or rotating it a bit.  Another alternative is to disable the internal compass by setting COMPASS_USE2 to "0".  That turns off the consistency check.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
