Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Rich:something that you need to do if you only use simple mode as safe mode is remember that always you have to position your copter in front of you and watching the backward part to you to take off, if not, when you switch to simple in an emergency the copter isn't going to respond as your espectative, the mode works cool if you have that caution, I prefer than super simple, included with compass interferences you can come back your copter, you can remedy with aileron stick in that case, I fly a lot with compass interferences waiting a gps+ext (that just today arrives :D ) and used simple a lot. Yes, experts Rc pilots hate it....but is not my case ;)
Yes, thanks for the tips!!
As an old time RC heli pilot, I always take off with the tail pointed at me, it's an old habit that is hard to kill!
As a not so old time pilot, I do this as well even though I started out on multirotors. I personally LOVE simple mode [no so much super simple]. When I started out it was on multiwii and I didn't even know about things like level [horizon], headfree [simple], or any other assist and it took me probably 2 months just to be able to not break a prop or arm per flight :( Then I leaned about hooking up the FC to the pc and enabling different flight modes and a whole new world opened to me. The pure fun part, not the oh god am I going to crash again part.
My issue flying these things is when they get 50 or so feet out and up they kind of all just turn black to me and I can no longer "see" which way they are pointing. LEDs help a lot but even so when I get 200 or 300 feet then even the LEDS just kind of look white so I lose orientation a LOT.
With simple mode that is not an issue to me as it no longer matters where the MR is facing. My controls are consistent and I can play around more actually flying it instead of worrying about crashing it :)
I also have it on a switch but I tend to enable it before take off so I know exactly which way my controls are at all times. I don't use it all the time but when I do I really am glad it is there.
I would not even consider flying without one of these now. It is VERY bright and even during the day with sun you can see it a long way away. I put the red up front and set the mode to blinking so it hardly uses any juice. I crashed a few times from simple disorientation I've not had the problem since. FYI I don't really trust it to be a low voltage alarm as it gets lower than I like. https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct...
If you have that habit, be shure that simple mode is going to work for you, the other tip that I use is, if for any reason my copter flies behind me (rare) I not turn my body, only my head, as you are flying in simple mode you have to mantain your body in the same position than you take off, Good Luck.
Thanks for sharing this!
I always thought the only place that simple / super simple modes would be confusing was if the operator was trying to use downlinked video from the aircraft. In this case it could be very confusing.
Otherwise, I would imagine that it should be a help.
But as others have said, if you are flying very close to yourself, and there was a GPS glitch, it could get confusing very fast. But I rarely fly that close to myself.
If anyone else has any success (or fail) stories, please feel free to reply. Or perhaps a separate thread is appropriate?
I fly fpv too, that one of the reasons that I prefer in a switch, you change to normal mode and fly normaly.
Ok, you two are worrying me now! LOL
SuperSimple mode says it works even if the bird goes behind you "The advantage over simple mode is that the controls are applied from the pilot’s point of view even when the copter flies behind the pilot/home location."
But I see your point, if GPS glitches happen, then where 'home' is could be wrong!
I'd like to hear from others as to how dangerous these modes are, but for now, I'll stop using them, just in case!
I have simple mode in a switch and used for two or three years without issues, I fly FPV and when return I switch to simple and land and no take care were the copter is pointing, I have as a safe switch too in case that I have to return with no fpv and no gps (redundancy safe), In combination with Poshold isn't a risk to crash if you confuse the switch, simply stop moving and solve it ;) (really are modes for vague pilots like me LOL, but works coooll)
Nice!!! Very Goool! ha
102
103
104
105
106
of 449 Next
