Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
The buzzer is pretty close but the pixhawk has its own vibration dampening separate from the buzzer. here is a screen shot with Acc XYZ also.
I had a similar issue with the proximity of the buzzer to the Pixhawk. Thorsten and Randy identified the problem (I moved the buzzer a few inches). Note that the problem of interference between buzzers and gyroscopes is being studied. See here: http://www.cio.com.au/article/581231/sounds-can-knock-drones-sky/
I agree with Thorsten that it's likely caused by the buzzer. At the moment that the vehicle switches modes the Z-axis accelerations on the two IMUs separate. The MPU6k thinks it's falling, the lsm303d thinks it's climbing. This is the 3rd incident of this now, makes me think we need to change the tone of the buzzer.
Randy,
what is interesting is that it seems not to be direct vibration in this case. In one of my logs I saw the buzzer tone in the mag data. So maybe it is magnetic interference. Or sound pressure - which is vibration again...
A picture of the buzzer mounting distance from the pixhawk in the attachments. Its a little disassembled but I'll put it back together the way I had it and test it without the buzzer connected.
just remove the buzzzer :)
in any case we receive all the relevant info via telemetry either on MP or tower...
after more than a year of using pixhawk I can say that buzzer is more of an annoyance than help.
I removed it on the third day and never used on any subsequent installations.
p.s. I do not use safety button either :)
It gives you additional safety. Depending on the telemetry allowed you can have signal loss from time to time. And in this case I am happy about any buzzer response.
Neil,
it is most probably due to an inconsistency between the accelerometers induced by vibrations from the buzzer when switching flight modes. Some discussion can be found at: https://groups.google.com/d/msg/drones-discuss/1xgJUpENNO4/gyk76r5E...
What is interesting is that the vibration damping is separate in your case. Can you post a picture of the setup?
Do anyone know if I can use solid state relays on my PX4IO board and how should I setup em (map to specific RC channel) if answer is positive.
Is it possible to turn em on say on "arm" action?
Not sure this is really an AC3.3 testing question so perhaps shouldn't be raised in this discussion. In any case, the Relay wiki page is here including instructions on how to control it from a switch. It's not possible to link it to an arming action.
227
228
229
230
231
of 449 Next
