Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hi, had a crash/hard landing with version 3.3.2. The quad was flying quite nicely until the battery failsafe kicked in and the quad quickly became unstable and went down wobbling hard. The quad was below the configured RTL altitude at the time of the failsafe event. The log shows that the throttle output saturates and the angles don't follow command when failsafe begins. Can anyone here see the cause of the problem? Here's the Log
    2016-02-10 17-24-05.bin
    • your battery couldnt handle the current it takes to climb in the initial stages of rtl. It looks like you are using a very low c rated battery, and it was dead by the time RTL kicked in. Set your voltage failsafe higher to avoid this in the future.
      • Thanks Craig, I was indeed using a low c rated battery. Turnigy Multistar 10c 8Ah to be exact.
  • Hi Randy and friends
    Is it possible to change the height at which copter transitions from RTL to land .. I know you can set the land height to 0 for Land and RTL to a height to return at, but it is the section where it pauses to enter landing mode. I would like to change this height but I don't see any setting in MP for it. Is it possible?
    thanks
      So you're talking about the altitude at which it slows from the WPNAV_SPEED_DN (normally 1.5m/s) to LAND_SPEED (normally 0.5m/s).  I'm afraid the altitude is hard-coded to 10m above home unless the vehicle has a sonar in which case it will slow at the higher of 10m or when it first detects something below.  We could add a parameter for Copter-3.4 perhaps.  Just to understand the use case, I guess you would like to make it lower so it gets down faster?
      • Hi Randy !
        Well, I would like to increase the transition zone to say 14m as its a very heavy large copter and when it descends its struggles to slow enough at the land zone height and we have one hard landing already .. I know I can set the WP Down speed but if i make it slower when it comes down from 200m its a long time for the descent .. so I have increased the WP Down speed and now need to raise the land section  from 10m hard coded to approx 14m.. unsure until its tested.
        cheers
          Reuben,
          Did that incident happen with a version before Copter-3.3.2?  In 3.3.2 we fixed an issue with how the landings were being done that should stop it from having the hard landings (see release notes here).
          • Yes Randy pre 3.3.2 on this machine we are still running the old version..I think it still on 3.2.1 :)  It was landing fine..infact we have done so many missions with this unit with no issue .. but it is a bit heavier now and i did increase the WP NAV down speed.. so it did no take so long to lose altitude after clearing some high terrain and enter its Land stage. Now it surpasses the safe height due to increased acceleration..Kinda drops like a stone and does not have enough time to pull up. and yes the copter has heaps of power and hovers around 450
              Reuben,
              Ok, so if you could give Copter-3.3.2 a try and see if it still has the problem that'd be good.  If it does still have the problem, just post a dataflash log and we can have a look.
              • Hi Randy .. I dont think posting a log would help, as I am sure its just descending too fast, to slow before Land kicks in .. It has been flying great for over a year now :o)
                On a sad note a new Giant quad build  1200mm with 135kv motors and 26 inch props, after great month of flight testing on 8s packs flying with a 3.5kg load for 40 plus mins ! It was running 3.3.2.. It came crashing down today from 70m and there is not much left of it .. big dollars lost of that one :o( .. almost everything is damaged. We were flight testing some tuning to see if we could get it more stable when i think a motor arm rotated in the boss.. and it started spinning and doing cart wheels nothing i could do to save it .. here is the only photo I have of it in prototype stage..sitting on top of a 42inch telly :o) I dont think large Quads or copters do well as the larger motors and big props are too slow for fast changes required for good stable flight. I think using the same motors but on 12s with 20 inch props may do it :o)
                3702913304?profile=original
DIY Robocars via Twitter
RT @knightsautoteam: Hi @diyrobocars, we are Orlando's first Autonomous racing club and would love your support. We are hosting our first K…
11 hours ago
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #14 - #ParkingLotNerds join us January 15th for #AutonomousRacing #RoboRace ⁦@DAVGtec…
Monday
RT @chr1sa: And after that came our races, 50 in all. This battle between these two Russians was the best we've ever seen -- incredible fig…
Monday
RT @chr1sa: Before our @DIYRobocars virtual race this weekend, we had a presentation from the team that won the Indy Autonomous Challenge i…
Monday
DIY Drones via Twitter
Dec 12, 2021
Dec 12, 2021
RT @chr1sa: Just a week to go before our next @DIYRobocars race at @circuitlaunch, complete with famous Brazilian BBQ. It's free, fun for k…
Dec 4, 2021
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Nov 28, 2021
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Nov 26, 2021
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25, 2021
@gclue_akira CC @NVIDIAEmbedded
Nov 23, 2021
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23, 2021
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23, 2021
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20, 2021
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20, 2021
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9, 2021
