Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • T3
        Yes, the accel values look very good but the vibes are relatively high.
        Adolfo, can you make s short test with IMU_RAW logging? I am really interested in this because the vibration on my copter seem a little higher compared to yours but the vibes on my one are much lower. Maybe a FFT analysis can provide some insight.
        Thanks and best regards,
        Thorsten
        • Here you go.
          First couple of minutes it is hovering in the same place. Then you have some really easy flying in poshold and then some really hard poshold flying. You also have some full pitch forward, full pitch backward and also full roll left and full roll right.
          Do I need to worry about something or are my vibrations safe ?? To me it flying well. I don't know more to be able to spot if something is wrong.
          Thank you
          3702793546?profile=original
          3702793472?profile=original
          3702793325?profile=original
          3702793569?profile=original
          3702793346?profile=original
          3702793484?profile=original
          3.3_rc8_IMU_RAW
          • T3
            Adolfo,
            thanks a lot for testing!
            I just had a very short look. It seems you enabled IMU_FAST instead of IMU_RAW (because I could not run an FFT in MissionPlanner).
            What is really interesting is that the Vibes closely follow vehicle movement - although the idea behind is to "remove the vehicle’s movement and create a “accel_vibe_floor”. This is visible in my logs as well to some degree but your flight was longer and maybe much more aggressive.
            Could you please try again with raw IMU logging?
            Thanks again!
            Cheers,
            Thrsten
            • Didn't Rob explain its supposed to be like that? They are accelerometers after all and I really pushed the hexa to the limits so they are measuring the actual aceleration during maneuvers. The "grass" height is actually very consistent and within the range.
              I had both enabled. Fast and raw. Tomorrow I'll give it another try if the weather allows it. It's night atm.
              • T3
                Hi Adolfo,
                maybe Fast and Raw are not working in parallel. If Raw is enabled Acc1 and Acc2 are logged not IMU1 and IMU2.
                Regarding the "grass" vibrations seem to be no problem on your setup. However, I would appreciate if you could give RAW (only) another try. Just a short non-aggressive flight :-)
                Thanks!
                Thorsten
                • Tell me exactly what you want me to do during flight.
                  Another 2 min of loiter in the same spot and some cruising around again in loiter ??
        • Yeah, I've talked about this before, we need to have a better understanding of what we're seeing in the data.
          My gas helicopter has really high vibration visible on the IMU.Accel logs, but the Vibe analysis shows the vibe levels very low. Leonard says this is because the Vibe logs show only high-pass filtered logs, so my gas helicopter has only low frequency vibes.  That makes some sense, because it's got a really good physical vibration isolation system.
          • It is an interesting topic, those vibrations. Both vehicles i have now have very little level of motor/prop vibrations under calm no wind conditions but i noticed when i get small one up high enough and it starts adjusting position to counteract even slight wind i get a period with a lot of instability. I wonder what variables dictate level of aggressiveness for those corrections so i could try to adjust that.
            It can also be seen in circle mode if i take a video - at some angles during rotation everything is smooth and nice and then at some angle it starts to shake hard enough to get jello all over. It does not seem to be normal, and it seems definetely related to a certain yaw angle relative to the wind direction.
            I will try to replace props next week to see if that will help but it would be great to learn what else can be adjusted in parameters to smooth up transitions.
            It is important to note - at low altitude it is as perfect as can be in all modes and all angles.
          • But it's not clear to me how you can have low vibes in the Vibe log, but high vibes in the IMU.Accel logging.
