Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Today I testet my LIDAR, connected via PWM. It works great in AltHold and PosHold.
    But in Auto mission the LIDAR is not working. I hat a Mission with descending to 2 Meter. The 2 Meters are barometric, If I put some thing under the copter there is no reaction from the Copter. I guess this is a bug.
    Also the RNGFND_OFFSET makes no changes even if i put in extreme values.
      Andre,
      Yes, I'm afraid that the Lidar is only curently used in manual modes (AltHold, Loiter, PosHold).  It's not used in AUTO.  That was the case with AC3.2.1 as well by the way.  Hopefully in AC3.4 we can get that working, it's not trivial though because we will want the user to be able to specify for each waypoint whether it's an altitude-above-home, altitude-above-terrain or an absolute altitude.
      • This would be a huge improvement for our company.  We've got a 1300 X8 for carrying lidar, but the lidar is limited to scanning no higher than 80m.  For our mountainous terrain and huge tree canopy, there's always a possibility of a tree collision.  The possibility of using the lidarlite (or scanning version) could save our large lidar from being damaged.  I was talking to the owner of Phoenix Lidar about integrating his AL3 into the autopilot.  The Velodyne 32 head scans 10 degrees forward and 30 back.  No reason is couldn't help with terrain info while it's scanning for topography.
        • Shaun: (sorry to the group for an off topic question) why lidar for topography when you can get high resolution 3D from photo images with SFM through software like Agisoft PhotoScan? perhaps a reply by email fredojean-at-gmail.com. Thanks a lot. Fred
          • SFM is a great, inexpensive tool for bare earth.  Unfortunately rarely do we have bare earth.  Volumetrics at excavation sites and open pit mines are really your only customers.  Lidar penetrates vegetation with multiple returns (not all lidar though, some single return).  Density is also much more consistent, don't believe all the SFM coolaid lol.  Bad light = low to no density.  Now to make this on topic, any way to incorporate our 700000 points per second lidar data into arducopter 3.4 code for collision avoidance : )
            • Thanks a lot for your quick (!) response. Limited knowledge of lidar; I didn't realize it has that penetration...  700k/s: that would be quite a bit more data to process. : ) = ironic or happily wishful?
      • Oh, I understand. Of-course it is a very good idea to have different altitudes selectable for the mission, that makes it safe and easy to understand. So I will hope for 3.4
        But as Roberto asked, I guess in Guided-Mode it is easy to get it working as per default?
          It's also not used in Guided mode I'm afraid.  Guided mode is really much more like Auto because the user still normally inputs a target location (including altitude).  Once we're talking altitudes (instead of climb rates), then only way to handle it correctly is to allow the user to input either an alt-above-home (like we have now) or an alt-above-terrain (i.e. lidar-alt).
        In guided ,too it isn't used ?
        best
        Roberto
  • Good Morning Everyone,
    Here in Italy is morning (=
    GEOTAGGING AND LOGS
    The issue about the logs and the GeoTagging with rc8 has been resolved?
    I had posted a log and an explanation of the issues some days ago in this thread but I didn't see any reply.
    2 GPS
    The issues about a sudden movement when switching to another GPS has been resolved?
    I talk about this:
    https://github.com/diydrones/ardupilot/issues/1875
    OPTICAL FLOW
    I also was doing some test with sonar and optical flow.
    I have this sensor:
    http://copter.ardupilot.com/wiki/common-optional-hardware/common-op...
    I would like to ask:
    Can anyone confirm that I need only to attach the I2C for a complete working Optical Flow+Sonar?
    The serial on the rear of the sensor is not used. Is this right?
