Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                  • I would not even consider flying without one of these now. It is VERY bright and even during the day with sun you can see it a long way away. I put the red up front and set the mode to blinking so it hardly uses any juice. I crashed a few times from simple disorientation I've not had the problem since. FYI I don't really trust it to be a low voltage alarm as it gets lower than I like. https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct...
                • If you have that habit, be shure that simple mode is going to work for you, the other tip that I use is, if for any reason my copter flies behind me (rare) I not turn my body, only my head, as you are flying in simple mode you have to mantain your body in the same position than you take off, Good Luck.
            • I set up my friends TriCopter to use super simple mode.
              He has 3 flight modes on his only 3pos switch, Alt Hold, Pos Hold and Alt hold with Super Simple although I've renamed it Home Lock mode for him.
              Although he only has 3.2.1 on an apm2.6, it's worked flawlessly for months now. As long as you're aware of how it works (pitch and roll are relative to you and not the uav's orientation) and how to engage it I think it's a great addition to regain orientation without resorting to RTL.
              • Thanks for sharing this!
                I always thought the only place that simple / super simple modes would be confusing was if the operator was trying to use downlinked video from the aircraft. In this case it could be very confusing.
                Otherwise, I would imagine that it should be a help.
                But as others have said, if you are flying very close to yourself, and there was a GPS glitch, it could get confusing very fast. But I rarely fly that close to myself.
                If anyone else has any success (or fail) stories, please feel free to reply. Or perhaps a separate thread is appropriate?
                • I fly fpv too, that one of the reasons that I prefer in a switch, you change to normal mode and fly normaly.
        • Ok, you two are worrying me now! LOL
          SuperSimple mode says it works even if the bird goes behind you "The advantage over simple mode is that the controls are applied from the pilot’s point of view even when the copter flies behind the pilot/home location."
          But I see your point, if GPS glitches happen, then where 'home' is could be wrong!
          I'd like to hear from others as to how dangerous these modes are, but for now, I'll stop using them, just in case!
          • I have simple mode in a switch and used for two or three years without issues, I fly FPV and when return I switch to simple and land and no take care were the copter is pointing, I have as a safe switch too in case that I have to return with no fpv and no gps (redundancy safe), In combination with Poshold isn't a risk to crash if you confuse the switch, simply stop moving and solve it ;) (really are modes for vague pilots like me LOL, but works coooll)
          • who me?? lol
            Yea my bad I meant super simple. compass only...if it flies behind you and YOU turn around then the controls will seem reversed but they actually stay the same. I decided very early on NOT to fly in either of those modes because if you learn that way you can really mess yourself up later on trying to break those impulses. One exception is I could see using super simple as sort of a manual type of RTL if you accidentally flew out of sight or something.
          • all is good while it works as designed. orientation of controls in simple mode only depends upon your compass orientation at the time you got vehicle armed. it stays same and it is good.
            super simple relies on the GPS coordinates and alters controls based on that position. when your position flickers suddenly - it will affect controls IF it thinks drone went behind your position on the ground. then it may flip back as GPS improves, then flip again. drone meanwhile will do weird things in the air with no possibility for you to save it.
            that is why based on my own experience I say - do not use 'super simple', ever. not until whole mess with reaction to GPS input will be reworked and improved to the level where it is 100% safe.
