Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Duffy,
That's included in the 3.3.3-rc2 beta release candidate actually. It was included in 3.3.3-rc1. So feel free to give it a try and ping me here if it doesn't work for some reason.
Randy,
my reply got truncated I think.
But I installed the 3.3.3rc2 beta and install the SF10/C via I2C, made the changes in config but it doesn't look like it is producing any reading. sonar range and sonar voltage are 0
Thanks Rand
Randy: which modes works now with Lidar lite? auto is not include yet?
Cala,
No, I'm afraid Auto still isn't included yet. Even if terrain following makes it into Copter-3.4 (we're going to try to include it) I suspect we won't get the google-map + lidar data mixing working until Copter-3.5. It's a bit trickier than it first appears.
Thank's Randy. I'm not hurry I have to recive yet, install, learn to use, etc. only to know.
Thank's Stephan
In 3.3.2 since we are logging more data now, would this be why I am missing a heap of camera trigger logs? I have 89 photos but only 68 cam triggers! Could it also be the fact that I am only using a class 4 sd card? I guess it is now safe to reduce some logging or try a faster card .. what do you say guys? I have lost some important info on a mapping job today. Grrr..
Reuben,
That's no fun. Yes, it's very possible that you're right. We've greatly increased the logging which helps a lot for digging into support issues (especially those involving the EKF) but has made downloading much slower and occasionally messages are lost if you're not using a high quality card.
I'll bring this up with the other devs (I've brought it up before as well) as a counter-weight to the constant desire for more data. We do actually have some plans to change the way we log. So instead of turning on/off individual messages, we hope to allow selecting the amount of data you want (i.e. "none", "small" "medium", "detailed").
Sorry for the troubles.
30
31
32
33
34
of 449 Next
