Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
i have a LIDAR and i must lift of the Copter for Prearm check to 50cm and then down. i´m not sure thats the same with a Sonar. i think so.
I had read that a few days ago so it's the first thing I tried but to no avail. Hopefully one of the developers can let us know what the preflight check looks for so we know what to do about it, or better yet, fix the check so it works properly.
I was just getting ready to go out and try this with the sonar removed from the arming check but there is no indication in mission planner what code to use. I re-enabled the sonar anyway and now I can get the check to clear by lifting the quad up. I may have tried this before after I had pressed the safety switch... I'll check that out later. In any case, at least I can get the sonar to work.
ARMING_CHECK -33 , skip the Sonar/Rangefinder Check
Thank you Pit. What I discovered is the sonar is working and I can clear the arming check by lifting the quad provided that I am on a hard surface (not grass). I don't know whether it's the sonar causing problems or that the check doesn't allow enough variation in the signal for uneven surfaces.
hi! will the telemetry mod for X8R and taranis work with the latest firmware? I am planning to do the mod on my setup so that the telemetry data will be pass to the x8r receiver via smart port and Teensy board. but I am concerned if this will still work with the AC3.3rc4 or higher.. thanks again my friends!
This is what I use https://drive.google.com/folderview?id=0B-B7PQy0joGrMjEyQWg1LXpoN28...
thanks my friend!
I'm using rc4 with x8r,teensy lua script on mine and everything works fine.
