Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Hi,
    Could you pls explain what is the actual purpose of having Storm32 connected to pixhawk via serial port?
    What specific functionality you use that requires that?
    I only use one channel sent to storm32 to alter tilt of the camera, do you use anything more than that?
    I`ve heard some people somehow use GPS coordinates to track s stationary ground object, but it escapes me how to implement that. Is there a resource anywhere with samples of such integration designs? I am just curious.
    Regards, Paul.
      I think using the serial/MAVLink connection is better than using PWMs because ardupilot can then specify the exact angle that it wants the gimbal to move to.  With PWM signals I think ardupilot can only specify where in the total of movement it wants.  They're equivalent if the SToRM's parameters match the ardupilot MNT_ parameters but in any case it's less direct.
      • Randy,
        I feel like I am missing something in this 'ardupilot can then specify the exact angle that it wants the gimbal to move to'.
        Where is this angle coming from? I can only think of the application where gimbal would be pointed at some spot on the ground, and, then, say, do a circle around than spot having gimbal tracking this target, but as I get it - it is not something that can be easily done, it would require tracker on the ground giving GPS coords of the target into the ardupilot and, frankly, I am not even sure if anybody did a prototype of this feature reliably enough to even spend time on this.
        There was a talk about 'boat feature' where drone would 'follow' you as you move, but, again, as I understand it all still somewhat in the prototyping stage with nothing really working.
        But if we speak of a generic task to just adjust single tilt angle - what would ardupilot talk to storm32 in this case? Or am I missing something global here? I just split signal from X8R receiver into storm32 and pixhawk and it works fine, but if storm32 would benefit from having getting data from pixhawk - what other data except channel9 with tilt angle value would it receive?
        Is there anywhere a good article describing 101 of such integrations?
        • @Paul,
          easy job, basics of trigonometry.
          If you fly over an object on the ground and camera tracking via gimbal is on, so geolocation of the object on the ground (lat, long, alt)
          can be easily calculated from gimbal angles, GPS geolocation, altitude over the ground (barometric sensor, sonar, 2D/3D maps) supported by timing.
          So your drone can fly around having camera pointed at the object permanently.
          This is just how gimbal really works.
          If interested to have this feature implemented
          just email me
          darius
          manta103g@gmail.com
          • Isn't that already implemented though as ROI in MissionPlanner?
            I know that if I specify an ROI in an auto mission the quad will face that ROI and adjust the tilt of the gimbal to point the camera at the altitude specified above the ROI in mission planner.
            As for the specific angle, having seen a demo vid on YouTube, I was under the impression the do mount control specified an absolute angle based on the quad. IE, -90 is straight down, 0 is straight ahead and 90 is straight up.
            • @MarkM you are exactly right. ROI or region of interest (or approximated point of interest in 3D space) is selected manually by pointing gimbal camera at ROI (fuzzy Point Of Interest). 3 temporary angles of gimbal camera are saved and used to solve an equation of a stright line connecting point described by the geolocation of the drone and projection of that line with the ground plane at altitude saved on take off. Since Region of Interest or Point of Interest on the ground is now geolocated (fixed) so for any new geolocation of the drone in 3D space equation of a new stright line connecting 2 known, geolocated 3D points can be solved to calculate a
              • @Paul,
                if you mean personal driver's drone as one offered
                by Rinspeed Etos and landing on a moving car,
                I can implement such technology if budget is secured.
                I have offered Rinspeed Company from Switzerland   Pizza Delivery Drone and Mind Controlled Drone technologies since they have budget to fund these technologies and implement them into consumers' market.
                If there is a simple solution for that, it would be great to know how to do it - to get drone up and film a car on a track, or a boat on water with automatic landing to this ROI location as well.
              • @Paul,
                Video tracking can be easily implemented into your drone
                since video object tracking is a standard feature implemented into security, monitoring cameras today.
                I have presented paper on tracking flying objects by a number of smartphones to get track calculated on the fly (meteor fall)
                at Vienna Conference.
                Moving object tracking by gimbal camera can be implemented as a default feature if there is any interest shown among drone pilots.
                Just let me know.
                darius
                manta103g@gmail.com
                I know some people worked on the method to track a moving ROI, so to say, but I have no clue where this development is now. If there is a simple solution for that, it would be great to know how to do it - to get drone up and film a car on a track, or a boat on water with automatic landing to this ROI location as well.
              • I see. I know what ROI is but it was practically useless feature as it is extremely rare when you would need to film around a static target that does not move.
                Still, thanks for pointing this out. I will try it during gimbal setup next time I get to it.
