Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Artem,
Sorry, yes, you are absolutely right. The pilot can always control yaw in any flight mode (except Guided maybe?). This is a bit of a odd ball that we haven't discussed much. Some pure-ist would say we shouldn't allow yaw control except in manual modes. Others say that it's convenient because it allows pointing the camera during missions, etc. Unless you really spin the vehicle around quickly, modifying the yaw doesn't affect the position control during RTL, Auto, etc so it's generally not dangerous to allow the pilot to control the yaw.
Good to know. I guess the only potential bad thing about allowing yaw would be if the copter is not tuned properly, motor imbalance, or esc sync issue. Sometimes yawing one direction can cause quick altitude drop or gain depending on direction of yaw.
Sorry, I never use Fence yet, but I experimented many time ago if I tried to fly when the copter was trying to RTL i finished inside 2 mts tall sunflowers :O , but less experience them to be shure what happened.
For my experiences, I have the sensation that, when the copter is in automatic modes, he don't want that human pilot distract him.
yeh I use Fence as a "safety net" - it's there in case things get out of hand. Even if you set up a very wide fence well outside of your planned flight distance at least you have one in place.
I'm hoping one of the dev's here can set me straight on what may have happened with the control loss after rtl was invoked.
Randy: It's possible to add to new vers a prearm check against distracted women safe?
If the pilot try to take off in an undesirable mode like Land or autotune for ex. prearm check don't allow you to take off?.
When this can happend? when you have land or autotune in a switch and forgot to unswitch the copter take off completly uncontrolled, autotune goes up and down crazy, fortunetly my copter is designed for that distracted woman and no crash consecuences. :)
What's mean "Err flight mode 15"?
Only a detail, 3.3 is nice. Updating to rc1. Thank's
Cala,
"Err flight mode 15" would mean that it was unable to enter AutoTune (AutoTune is flight mode #15). This could happen if the vehicle wasn't in AltHold when you tried to engage AutoTune.
Many thank's Randy, that's explain all; I notice that when the copter can't engage one mode, becomes crazy, I observed in 3-4 oportunities, It's possible to change something in code if copter can't engage a mode stays, for ex in the last mode that was flying well and no become crazy? I observe in the two copters and with APM 3.2.1 and 3.3; only to take in mind, we have to pay more attention what we are doing when we fly too ;) .
Cala, when it can't engage a new mode, it simply remains in the previous flight mode. There should be no impact on the current flight mode at all, it shouldn't become crazy. If you're seeing crazy behaviour probably best to provide a dataflash log.
Many thank's Randy, here is the last one, The problem was at begining with autotune switch engaged by accident (distraction), I take off and copter become uncontrolable.
https://www.dropbox.com/sh/j4yvrd4zj9tk7yg/AAC7om2GayyPMJ5EGOZ-1nfY...
Hi folks,
I'm new to this community and I must say great work done my many here, thank you.
Quick question. I just upgraded from 3.2.1 to 3.3. How do I turn off the low voltage audible alarm while my Pixhawk is powered by USB without having to set FS_BAT_VOLTAGE to zero then remembering again before flying. It didn't do it in 3.2.1. Voltage does read correctly on the HUD so I don't need to calibrate the device.
Thanks,
Bob
