Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • @Fnoop thanks for education. I am using FollowMe since its introduction extensively in my DIY stuff and with Solo, and know how it works.
            Call it whatever you like, but having the drone speeding away when you hit Pause is not what you want.
            @Randy thanks for having a look, if you need more data let me know.
            Here is a short video about the incident
            http://youtu.be/WGdAYg2UGJU
              Stephan (sorry for the incorrect spelling before),
                   I've recreated the problem very easily and I'm digging into the cause but I haven't figured it out quite yet.  I'm not even sure yet if it's in Tower or Copter.  I'm going to be off this afternoon and tomorrow so unfortunately this bug is going to survive another 48h but it's top priority so it won't make it 'till monday I predict.
                   Thanks for reporting this!
              • Thank you Randy for looking into this.
                Please take all the time you need.
                Btw it worked perfectly well with 3.2 and also no issues with Tower along with Solo.
                A recent change on my end was to add a LidarLite via PWM.
                warm regards
                Stephan
                  I'm pretty certain the bug is within Tower and not Ardupilot.  I've created an issue for Tower here and although I haven't been able to again recreate the issue exactly, I've been able to make the Pause button cause the vehicle to fly off if I first make the vehicle report a bad GPS position.
                  Pause button causes Copter-3.3.2 to fly off · Issue #1695 · DroidPlanner/Tower
                  I&#39;ve reproduced this problem just now after being reported by Stephan on the Copter-3.3-beta testing thread. I&#39;m looking into the cause as a…
                  • Randy, please find the tlog file attached.
                    Let me know if you have any further questions
                    Best Stephan
                    log_usb_2016_01_03_11_53_20.tlog
                    https://storage.ning.com/topology/rest/1.0/file/get/3702948915?profile=original
                  Stephan,
                  Strangely, although I produced the problem once very easily, I've been unable to reproduce it again despite hours of trying.  Also we do not record the commands received from Tower in the dataflash logs (I will add them) so I cannot see if it's caused by Tower or ardupilot.
                  Could you try and find the .tlogs from Tower from this incident?  I tried myself but there were no logs recorded on my tablet.
                  The logs can be found by connecting the tablet to you computer, then (if you're using Windows) go to the file manager and look for the tablet's name.  open that up and under ../Android/data/org.droidplanner.services.android/files/tlogs you should see a bunch of tlog files dates in the filename.
              Stephen,
              I didn't get to this today but tomorrow for sure!
            • I wasn't trying to lecture you, just point out the fault might be with Tower not APM and it's not uncommon to hit glitches in the more complex modes.  Hopefully Randy can narrow it down from the log.
  • Ran into a strange defect with AC 3.3.2 and Tower latest release today. Was my fist set of flights in FollowMe with 3.3.2
    1. Fly in Guided (Follow Me)
    2. Press pause, the copter will accelerate immediately and fly off, can only be saved by switching into another flight mode via RC control - Loiter in my attached log.
    The defect is fully reproducible, I tested this twice in 2 separate flights after a power cycle in between.
    Very annoying and dangerous. W/o the RC transmitter in my hands the drone would have gone straight off and crashed somewhere. Log file attached.
      Thanks for the report.  I don't see your log file attached..
