Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • It would probably help Randy / Devs if you could post a log. Bummer about the broken leg :[
      • Thanks Richard.
        I'll only have access to the Iris tomorrow. I'll put them up then if no one has a flash of inspiration in the meantime.
          As Richard says, it's guesswork without a log.  The rapid descent at the end is almost guaranteed to be because the battery was getting very low - if so, we will see in the logs that the output throttle was at 100% as it was falling.  This basically means that the battery failsafe needs to trigger earlier.  It could be as simple as setting the failsafe voltage higher or the battery capacity lower.
          • Here are 4 logs to download with graphs for quick view: 2 failsafe crashes, 1 successful RTL test and 1 successful Land test
            Crash 1: https://www.dropbox.com/s/gr2jipj4u1jwnxx/282.BIN?dl=0
            3702846044?profile=originalCrash 2: https://www.dropbox.com/s/r5948y8ovswripn/284.BIN?dl=0
            3702846061?profile=originalSuccessful RTL tests: https://www.dropbox.com/s/b7bg46rhplwmo73/283.BIN?dl=0
            3702846079?profile=originalSuccessful Land tests: https://www.dropbox.com/s/2cva9etzclh96gl/287.BIN?dl=0
            3702845962?profile=original
            282.BIN
            Shared with Dropbox
            • Frederic, is you Iris modified in any way?
              Does your buzzer go off when the battery failsafe kicks in?  It usually does.
              Thorsten had a problem similar to this where he found the problem was actually that the buzzer caused a problem with the IMU, because it was too close.  I would think the standard Iris buzzer location wouldn't cause this problem or they would all do the same thing.  But maybe your buzzer has been moved or something?
              • Hi Rob,
                It's an upgraded Iris that I bought new in June 2014. Aside from installing the Iris+ upgrade kit, I made no mods. The upgraded Iris never exhibited this behaviour before, and I've relied on the battery failsafe many times.
                Yes the buzzer does go off when the failsafe kicks in. I have not moved the buzzer - it is inside the top shell. I've opened the shell yesterday to get the logs off the memory chip and did not notice the buzzer being loose.
                Thanks a lot for your help.
                • T3
                  Hi Frederic,
                  I just had a look at one of your logs and I am pretty sure it is the buzzer. It is the exact same thing I experienced. When you switch a flight mode there is a buzzer tone and the IMU readings diverge (yellow and orange lines):3702926936?profile=original
                  In these cases my copters were either falling or climbing for some meters (which seems not to be the case with your copter). After relocating the buzzer all was fine.
                  Looking forward to your test!
                  Best regards,
                  Thorsten
                    I'd just stick with the 3M foam that 3DR sells.  Paul Riseborough recommends the "Hobby King pink foam" but it's only sticky on one side.
                  • Ok - Thanks again Thorsten. I'll keep my eye open for softer foam to support the Pixhawk.
                  • T3
                    Hi Fred,
                    I have no Iris and no experience with it. Hence, I cannot give you any specific recommendation. I general I found the 3DR foam a little too stiff. But it depends how you mount the autopilot as well as on the weight sitting on the dampers. It is hard to find an optimal solution.
                    Anyway, the vibrations of your Iris seem to be within the limits. AccX is a little high. I would try to balance the props. This helps in most cases.
                    Cheers,
                    Thorsten
