Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                  Reuben,
                  Very sorry to hear about the crash.  No fun at all.
                  Probably hard to think about it much at this point but regarding the hard landings, with the fix in Copter-3.3.2 it uses the "leash" while descending.  This means it will start slowing it's descent rate at some altitude above 10m so that when it reaches 10m it's descending at the LAND_SPEED.  Previously it would change it's target descent rate at 10m, now it begins slowing much higher than that if necessary.
                  • Randy,
                     Is there a general advice/guidance on tuning large copters with slow motors and large propellers. I have previously had to use really high PIDs, in the range of 3.34 .(U7 420KV quad on 4S)
                     The new U8 135Kv quad on 6S, was rather unstable on low PID and I will be testing increase P at 3 and test flying again.
                  • Hi Ya . yes i think your are right i should try 3.3.2.on that machine, as you say it should start to slow sooner before 10m .. this is the issue, it races to 10m then tries to slow by that time its nearly touching the ground ... instead of racing down to earth then start slowing down before it hits the 10m... Yes losing that big machine is a hard one .. i think i will stick to faster moving props .. busy building a Y6 on 275Kvs on 8s ....trying to do the whole, more volts less amps thing :) i might try 12s on one of the sole survivors of the bigger motors on the test bench. ..
              • Had a noticeable drop in power twice while in ALT mode in test flights today.
                Frimware.Version: 3.3.2rc2
                 I also have SF10/C connected in serial
                 Log attached
                PS a bit unrelated but: This was the first flight of a large quad with 29"x9.5 props, and it wasn't tuned. But it was sluggish and unstable enough that I wouldn't trust to put it in autotune. I think I need to ramp up significantly the rates test fly and then tune
                • bin log here
                  Tony: temperature must have been ~5C
                  2016-02-10 10-51-40.bin
                • biggest question i would ask. Was it cold outside.?
    • Dang... I just looked for 5 minutes.. I don't see it either.. Just this .. I think it defaults to 10M but I know you used to be able to change that. Must be looking right at it!!
      RTL loiter time (ArduCopter:RTL_LOIT_TIME)
      Time (in milliseconds) to loiter above home before beginning final descent
      • Range: 0 60000
      • Increment: 1000
      • Units: ms
  • Randy: today a strong wind, I flyed with 3.3.3 pos hold and nothing strange; I'm going to try more things next days.
      Cala,
      Great, thanks very much for testing!
    Re Pixracer, we've done a special build of Copter-3.3.3 and put it in place on firmware.diydrones.com so you should be able to load the Quad code from MP's Install Firmware screen (either the default or "beta firmwares" links should work).
    So for now only the quad code is available but we will put the hexa, tri and y6 versions in place tomorrow.
    Because I used my pixracer to work with my QC snapdragon (aka "snappy") we have not actually test flown this exact binary so please be careful and it would be good if the first couple people reported back that it seems ok (or not ok).
    Sorry for the delay!
    P.S. because this pixracer build was done manually, MP's install firmware screen may initially tell you it's installing Copter-3.3.2 (or Copter-3.3.3-rc2) but it will actually install Copter-3.3.3.  This slightly bit of misinformation will go away when we do the official Copter-3.3.3 release.
