Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
              • FWIW looking at your photo again, I have discovered that the cable end of LiPo batteries give off a lot of magentic interference and now mount my batteries with the cable end as far away from the compass as possible. I suspect you have enough distance for this not to matter, but FYI.
                • Sorry to barge in and this has probably been discusses a thousand times 'somewhere' but do you think it's advantageous to put copper foil tape on the bottom of a gps case? I have the typical black round plastic gps case on a mast. Would copper tape on the bottom be a good idea? Seems a but less messy that copper foil on all the wires. Thoughts? Thanks
                  • copper base helps a bit. but what helps way better is to use properly filtered 5V voltage feed, from a BEC separate from the one that feeds flight controller. when i rerouted power and stopped using 5V from the COM port where GPS was connected to quality of data has improved tremendously, as well as speed of sats lock.
                  • So I've always been suspicious of this since I'm pretty sure every GPS has a ground plane anyway. I think the EMF interference is a field rather than unidirectional, so you'll be missing some of the radiation this way. That's why I think identifying the sources and shielding them is more effective.
                    But Cala's experience shows that it still works pretty well!
                  • I put cooper under gps on my last build, It's changed from 10-12 sats to 18-20 sats :O and I don't need a tall mast, only a second floor over the Pix, I connected the cooper to the pix with a ground wire.
              • Sweet! Glad you got it sorted.
                I think this kind of story shows just how vunerable GPS's really are and just how much the FC is using it. I had no idea when I first got into this. I'm also amazed how much difference shielding makes - its so much more convient than distance!
          • Could try connecting to ublox ucenter and doing a cold restart, then let it run for a while (30min?). I've had that help on big deviations.
            What hdop and # sats are you getting?
            • I'm not sure of the HDOP, that is prob in the log, but I usually have 10-13 sats within 10 seconds. Andy, I'm glad yours improved. I will try that and have results soon, too. Thanks for your suggestions.
          • I agree that 1.3Ghz could be wreaking havoc BUT having just been through this myself I think another highly likely option is the camera and video cable - neither are shielded and on my mini quad they were completely killing the GPS (vtx had no impact but that was on 5.8Ghz). I have what looks like the identical camera and I believe it leaks a lot of RF interference. Likewise the cable. Wrap both in copper tape and and that should make things a lot better. I would not advise putting the GPS above the camera for this reason - you would be better off moving it to the back. If you look at a fat shark camera setup the cables are always screened.
            See here:
            http://diydrones.com/forum/topics/using-camera-wipes-out-gps-signal...
            • Just a follow-up on this. Finally got to properly test my camera/cable screening solution (copper tape) and the difference is night and day! Before I was rarely getting a lock after many minutes and even if I did it was 4 sats high HDOP. Afterwards I was getting a lock in < 30s with 10 sats and HDOP 0.8 on an LEA-6H. YMMV as my camera is VERY close to the GPS unit (0.5 cm) but FYI.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
