Crash GPS?
Well after testing my first mission all was fine. upon the second mission it flew off on it own and i wasnt quick enough to grab it back. After some more missions and testing i see in my logs im losing gps. this is only happening when i switch it into auto mode while its in stab i have full 12-14 sats. i running a U-blox Neo-6m gps. its mounted at the back of the quad with the light (led) side facing up. have i done something wrong and how do i fix this.
Thanks Wayne
2013-11-21 12-26 332.log
2013-11-21 12-26 331.log
  • Yeah if thats the case then it is upside down. Thought it might be. So why is it working most of the time and not when i need it to then
  • The LED is on the bottom of my GPS. Did you perhaps mounted upside down?
    The electronic components should be facing down, and the smooth ceramic square antenna faces up.
