Crazy Magnetic Interference
I am having huge problems with magnetic interference when I fly my quad.  I had recalibrated the compass dozens of times, replaced the gps/compass, raised the gps as high as the wire will allow (10cm).  I even moved the battery and power wires under the frame.  But you can see in the logs where the magnetic field spikes which causes significant yaw drift and then soon violent toilet bowling.
System
DJI Flame Wheel 550
Pixhawk
External GPS on mast
Ardcopter V3.1.5 ( i even tried the latest beta release of 3.2)
8 45 blades
30C 2800 LiPos
You can see the toilet bowl effect and the magnetic field levels in the logs (attached).  Please, any help would be appreciated
2014-08-25 16-59-47.log.zip
  • Hi,
    Could you add a picture of your quad with all equipment etc installed ready to fly?
    I had issues with mine which was due to the telemtry aerial I was using, which would flex slightly in flight and get too close to the the compass in the process, changing the magnetic field almost randomly ... could be whats happening to yours.
    Also whats GPS/compass aer you using? I also had an issue with the metal screws of the 3DR GPS/compass combo case becoming magentised, however this was very evident when calibrating the compass (you would get very large offsets).
    S.
    • Sorry just realized my typo above. it is a 450 not a 550
      • Hi Ted,
        How is it going now? I am not expert at all at this hobby, but I saw that the Vx is pretty close  to the GPS (also at the same height), it might be the case? Hopefully it helps.
        • Do you mean the video transmitter?  Maybe, but I have tested with the video system disconnected and still had the compass problem.  It is still over 10cm away.
    • Here are some pics. I have tried re-routing the power wires several times but all with the same problem.
    • Will get a picture up when I get home. But I have tested with all other radios disabled, no video, no telemetry, even had the battery hang down over a foot below the quad.  Same issues.  Flies well, then starts to yaw drift, then goes into extreme toilet bowl.  Log data shows huge jumps in magnetic interference but I can't figure out what causes it and what condition initiates the problem.  I keep all the other radios at least 10cm away from the GPS
      My GPS is a 3DR, but I have tried 2 different units.
  • Hi,
    do you use a battery alarm connected to the balancer connector of battery ?
    • No.
  • This reply was deleted.
    • I have run compass mot many times but I have read that it is unreliable right now on the Pixhawk.  I have tried the new tool in the 3.2 beta as well. I have played with the parameters as well but I think the Pixhawk ignores those and uses the external if it connected.
        • I know, but I am desperate.  Need to try whatever I can and there are some compass improvements in the new version
