crc fail with XBee
Dear all,
Wen I use the USB cable I can communicate with my hexa: no problem
When I use the XBee I have problems:
- The user interface react very slow
- the terminal shows crc fail: "NavLink Bad Paket (Crc Fail)" very often: several times a second.
I use 2.0.40 software
XBee pro 50mW
Sparkfun USB Adapter on Notebook side
57600 speed.
What can i do? What I have done wrong?
thank you!
  • Admin
    Franz,
    Depending on the age of your SF USB Adapter, it may not have a voltage regulator that has sufficient current capacity to handle a Xbee Pro. The early SF USB Adapters would cause drop outs when used with a Xbee Pro. Do you have anyother USB adapters with regulators that can handle the current of the Xbee Pro to see if that is your problem? Take a look at these comments at SF concerning the USB adapter: http://www.sparkfun.com/products/8687
    Just a thought.
    TCIII
