CRIUS + Micro servo
How to make a servo actuate autonomously when reached at certain target (coordinate) using CRIUS AIOP and mirco servo.
Can anybody help me related to that problem. Is there need a programming??
  • Do you know how to program a flight plan in mission planner yet?
    After the waypoint, use Add Below to insert another, change to Do_Set_Servo. Enter the channel number and the PWM setting you want. Just use 1000 for one direction or 2000 for the other. No coding required, very simple.
  • Put Do_Set_Servo after the waypoint. Fill in which servo number and what PWM you want, like 1000 for close or 2000 for open.
    In the parameters the RC# Function should be set to zero.
