300km
Cruise airspeed and actual airspeed
Hi all.
I've been testing the effect of different cruise airspeed settings on power consumption, but in the range that I've been testing (8m/s, 9m/s and 10m/s) it has almost no effect on actual airspeed (or power consumption).
I've been flying a lap about 1.5km long, and changing the cruise airspeed each lap.
Working with the log files afterwards the average of the airspeed for each lap shows little or no relation to the cruise airspeed setting.
(Before you ask, yes I changed the setting in the Arduplane Pids screen AND clicked Write. It is recorded in the tlog file with a mavlink_param_set_t entry).
Below is a table of measurements taken from the log file. The first column is the cruise airspeed setting for each lap. The next columns are the average values for the named variable taken from the tlog file. The final column (Watts) is just current * voltage.
3691004666?profile=original
The only reliable effect that I've measured is alt_error. It's lower at high speed settings. Obviously the plane doesn't fly any faster, or use significantly more power to achieve that. (I've done this test three times now and I got a similar result each time.)
Do I need to change the THROTTLE_CRUISE percent value too? What does this do? Why is there a THROTTLE_CRUISE (%) and AIRSPEED_CRUISE (m/s) setting?
(I'm flying a Bormatec Maja with APM 2.5 and airspeed sensor).
  • It seems like you guys know airspeed control rather well. My goal is to hold a constant airspeed and currently it fluctuates about 0.2 m/s for every 10m/s of airspeed. How can I get arduplane to more accurately and concisely hold an airspeed?
  • I have the same cuestion.
  • 300km
    Probably that table is more complicated than it needs to be.
    My main point is that there is little or no correlation between the AIRSPEED_CRUISE setting (first column) and the actual airspeed (second column as recorded in the tlog file).
