DCM Bad heading
I had a crash today.
I loaded 3.2 a few weeks ago and haven't had any trouble with it, in fact, It has been excellent!
Today something happened that caused a crash, the damage isn't too bad.
However, I have been trying to make sense of it, and I hope if this is a bug in 3.2, it can be found and corrected.
The first thing I notice is that it appears when I play back the log in mission planner, the heading line for "current heading"  is 90 dg to the left from the way I pointed the front of the quad copter when I set it down for takeoff.
At the time, I didn't notice this in MP because I only used mission planner to wait until I got a suitable GPS lock.  I did get a good lock, at the point of takeoff, I had HDOP of 1.4 with 11 satellites.
However, after the crash. when I played it back, IT was obviously wrong.  The last time I flew, all was well, a very good flight and nothing was done or changed.
here is a clip showing mission planner in playback.
http://youtu.be/LDsfIxyOp70
Also, after taking off, I noticed what sounded like a disarm tone or something, and the motors just suddenly spun down.
To make this even more confusing is that the motor cutoff seemed to be triggered when I switched from Stab mode to Position Hold.
Since using 3.2, I typically set it into position hold for takeoff and pretty much the whole flight usually.  In this flight however, I took off in stabile, then switched to Position hold..
anyway, so here is the short video:
http://youtu.be/UqdKyD3747w
