After following the instructions in the ArduCopter Wiki and reading through the forums on the DIY Drones, it appears that I received a defective unit.The APM 2.0 board functions properly in stabilize mode and alt_hold but is not receiving and information from the built in GPS. When connected throughthe mission planner software, is states "No GPS" even though the GPS daughter board led gives a 3d fix indication. (Solid Blue Led).I am using Mission Planner v.1.2.1 MAVlink 1.0 and Arducopter 2.7.1In Mission Planner under Terminal Tests in CLI Mode "Altitude" and "Compass" return valid results while the "GPS" command returns G!G!G!G!.G!G!G!G!. etc…Please advise and help to resolve this issue as soon as possible.
I get the 3D fix led on steady with both power supplies.
Jason suggested that this might be a bad solder joint.
Anyone know of a DIY for re-seating the GPS daughter board?
Thanks in advance!
