Disable restart APM on USB connection using MAVProxy
I'm using MAVProxy to connect to an APM over USB, but the APM reboots when I run mavproxy.py.
I know that Mission Planner has a checkbox to disable this, does anyone know how I could disable this with MAVProxy? I've looked through the code, and can't see where in mavproxy or mavutil this is initiated.
J
  • Were you able to disable it?
    Also how do you code for mavproxy without messing with the terminal? using python for example?
