There hasbeen increasing discussion of application of the UAV Dev Board IMU approach to CCPM RC Helicopters. Bill and I thought it would be useful to start a thread on this specific topic and see what interest there might be.
My particular interest is to initially implement a stabilization system on my TREX 450SE Heli. Loftier goals of AP with RTL and WPs may well follow.
If you are interested in something similar, please post and describe your interests. Perhaps we can help Bill on some of the CCPM-specific issues.
Note: The Heli and Quad discussions have been moved to:
http://groups.google.com/group/UAVHeliBoard?hl=en
With the code and documentation at:
http://code.google.com/p/matrixpilotheli/wiki/TopLevel?tm=6
John
Hello everyone,
I'm trying to use the board for a VTOL model application and I'm addressing this Helicopter discussion thread because of need of stable hovering I need to achieve first.
The DCM algorithm and the board themselves seem to be more than helpful, thanks everyone involved but, in practice, there is a big limitation I encounter:
My idea of achieving stable hovering is to get the absolute acceleration of the model regardless of it's attitude (taking out the gravity component obtained through the DCM algorithm) and sending the X and Y axis absolute accelerations to PID controllers that would keep the model stable (even in windy conditions, etc.).
The code looks like:
// gravity measured in the frame of reference of the ground
fractional gravity[] = { 0 , 0 , GRAVITY } ;
// gravity measured in the frame of reference of the plane
fractional gravity_p_ref[] = { 0 , 0 , 0 } ;
// gravity component in the plane reference
fractional abs_acceleration_p[3] = { 0 , 0 , 0 } ;
fractional rmat_transpose[] = {RMAX, 0, 0, 0, RMAX, 0, 0, 0, RMAX} ;
read_accel() ; // to update gplane (acc vector)
setDSPLibInUse(true) ;
MatrixTranspose(3, 3, rmat_transpose, rmat ) ;
// get the gravity component in the plane frame of reference:
MatrixMultiply( 3 , 3 , 1 , gravity_p_ref , rmat_transpose , gravity ) ;
// substract the gravity component from the accelerometer readings:
VectorSubtract( 3 , abs_acceleration_p , gplane , gravity_p_ref ) ;
// project the absolute acceleration of the plane frame of reference to the the ground frame of reference:
MatrixMultiply( 3 , 3 , 1 , absolute_acceleration , rmat, abs_acceleration_p) ;
The success:
It really works: I play with the board and, regardless of the attitude, the absolute_acceleration shows something only if the position of the board changes, not the attitude.
The problem:
after few attitude changes followed by steady position, the absolute_acceleration converges very slowly to 0 and this would be a killer for achieving a good hovering. (this slow convergence is in fact visible in any component of the rmat, etc.)
The question:
Is there a solution to that by using:
1. Much better sensors (high precision accelerometers like SCA3000 , lower drift gyros, etc.)
2. Tuning of the algorithm for this particular case where tha acelerometers mesures mostly gravity (I've tried to play a little with KPROLLPITCH and KIROLLPITCH but couldn't get a difference)
3. Anything else inertial based or I need to move to Optical Flow stabilization (Parrot like)
Note: I've also tried the PNI SpacePoint which is Kalman filter based but that's even slower.
Thanks and Regards,
Dragos
If you are interested, please sign up.
We have a working version of MatrixPilot for Helicopters that stabilizes Pitch and roll, with Yaw stabilization coming soon. There is also a roadmap posted that describes the added capabilities we intend to impliment.
Best,
John
The new thread is here.
uses the gyros for the main source of yaw and pitch orientation information, with drift
adjustments coming from the GPS and the accelerometers.
I have been reading these forums with interest over the last year or so, i am an engineer and would love to try and start to build, help, develope with some of the guys here. I have been flying heli's for a long time and can hover on the spot in a gale :) thats not showing off, its just that i can install a system in one of my machines and test it. if it all goes wrong i can still bring the bird back as long as i have control on my sticks. I am going to purchase the uav dev baord and have a go myself. i understand this would be a long journey, but then learning to fly wasnt easy :),
Anyway if any guys in my area would like to get to together and have a go to build a system, then i have heli's with ccpm or without. I am up for putting in the hours and have a local club field for testing.
I hope i have put this in the right forum, if not then please say and i will delete it.
I am working on developing a stabilization controller for a Heli. Nothing too great to report yet, but the results are promising. The part that I think everyone is getting hung up on is sensor fusion. Anyone want to track: http://heli.selfip.com
Andrew
Here is a thread that discusses the issue
John
I am following the Ardupilot project, and have an Easyglider equiped with board, GPS and FMA sensors.
I am following another project led by Mikro for his Mikroquad and later Aeroquad (actualy experiencing problems getting it to work with my Futaba/Assan 2.4 radio)
I would be very interested in finding an open source GPS driven alternative to my Helicommand, so roll your sleeves ;-)
Thanks for starting this long expected thread :-)
Just in case you missed it, this board looks like it would be well suited for helicopters.
Bill
Thanks for the reply.
As I intend to pursue this project for educational purposes, i was thinking of acquiring the Analog devices triaxial Gyro coupled to a DSP! After hopefully achieving the Heli Stabilization I would like to dig further into an IMU+GPS; in case of the latter a DSP board would come in handy??????????? But ofcourse I could employ this DSP for other projects too.
I would definitely need help with the code. Perhaps if you can guide me initially,
1.How to filter the gyro outputs .
2.How is the correction thru the PI controllers applied to the concerned servos ( I have a 120 degrees Swash Plate)? Any Euler/quaternions applied?
3.Extended Kalman Filters; where do they exactly fit in the loop? Before the PI Controllers,I guess?
4. How do we tie up the Tx of the R/controlled Heli outfit with our proposed Stabilization Unit?
Sorry for the too many questions.Basically from building warships to Autopilots / IMUs is a huge gap but I am determined.
I rely on you guys for all the help.
I surely would like to chip in as much possible.
Sincerely,
muhammad
1
2
of 2 Next
