If you like building or customizing multi-purpose drones, you know how important FC bay space is.
There are so many flight controllers on the market, and having extra room makes it much easier to install or swap different setups.
What I like about the EFT X950 is that the space isn’t just large — it’s well thought out. The cable routing layout helps keep the wiring organized instead of turning into a mess. Even after installing the FC, receiver, and other modules, the bay still looks clean.
It’s not just about appearance either. Cleaner wiring helps reduce signal interference and improves airflow inside the frame, which is important for cooling and long-term reliability. Overall, it makes the whole build process much easier.
