I am about to start building a hex copter of my design it will be about 36"wLooking for advice about if the parts I am about to buy would workAll alum. ArmsMotors I am thinking will be the E-Flite 25 outrunner 870KV with 60 amp ESC15"bladesNASA with GPSAnd a FPV systemI have attach a pic. of the 550 I builtVary much like the DJI F550 but largerWhat do you think will it work.....?Thanks
Bigger is better maybe lol.
I own a security company that we do many different things and this is one other thing I am looking into and I can use it as a R&D and have fun at the same time.
I did look on the web about eCalc that looks like it may help me thanks for that.i will be probably be spending more then I should especially if it isn't going to work. I have about 2weeks till the arms are ready so till then I will keep looking into it and maybe touch base back with you then if ok. You know when you get something in your head you got to fallow it thru price that i am thinking of spending will be about 3000 to 4000 we will see
Mounting of the motors same way also just a larger hole pattern for motors
Sorry yes Naza M2 if it will work?
Weight not sure at this point I am told each arm is about 1 to 2 Lbs
I don't know about eCalc..?
ESCs under the arm same as the F550
