Do ESCs get damaged after props hit the ground
Hi guys,
When an drone crashes and the propellors hit the ground do the ESCs get damaged. My drone crashed one while I was flying and motor 1 hit the ground along with the propellor. The motor was damaged so I replaced the motor checked and the esc1 seemed to be working fine(Motor 1 was rotating). The next time I flew it the drone climbed and after a while the esc1 failed and crashed (The drone flipped to that side and one FET was also burnt). Was the esc1 already damaged after my first crash?. While taking off it worked fine but did it burn when the load was too high.
Should we replace the esc when the props hit the ground and how do we check if the esc is working
Thank you in advance
  • so you are considering seriusly repair that esc instead of pursache one new?
  • Depends of the sytem used by that particular esc..
    While the motor is spining, the impedance of the colis(wired in delta confiduration normally) is hig, because the magnet is moving to the center of the coil... is generated an extra back emf  ...
    but when the magnets dont move, or the same: the motor is not turning that extra back emf dont exist in the coils...
    so its only present the autoinduction factor, in consecuence the impedance is lower than the turning situation.
    so yes, is the motor is stoped more current is required and the transistors will dranin more current... but if the esc is good,
    it can avoid the burning od the transistor by having a dinamic limit...
    you can chek the state os your transistors with a amperimeter or an osciloscope comparing the esc outputs on a specific load
    maibe an esc manufacter will expalin this situation much better, anyone?
DIY Robocars via Twitter
How to use the new @donkey_car graphical UI to edit driving data for better training https://www.youtube.com/watch?v=J5-zHNeNebQ
Monday
RT @SmallpixelCar: Wrote a program to find the light positions at @circuitlaunch. Here is the hypothesis of the light locations updating ba…
Saturday
RT @SmallpixelCar: Broke my @HokuyoUsa Lidar today. Luckily the non-cone localization, based on @a1k0n LightSLAM idea, works. It will help…
Nov 25
@gclue_akira CC @NVIDIAEmbedded
Nov 23
RT @luxonis: OAK-D PoE Autonomous Vehicle (Courtesy of zonyl in our Discord: https://discord.gg/EPsZHkg9Nx) https://t.co/PNDewvJdrb
Nov 23
RT @f1tenth: It is getting dark and rainy on the F1TENTH racetrack in the @LGSVLSimulator. Testing out the new flood lights for the racetra…
Nov 23
RT @JoeSpeeds: Live Now! Alex of @IndyAChallenge winning @TU_Muenchen team talking about their racing strategy and open source @OpenRobotic…
Nov 20
RT @DAVGtech: Live NOW! Alexander Wischnewski of Indy Autonomous Challenge winning TUM team talking racing @diyrobocars @Heavy02011 @Ottawa…
Nov 20
Incredible training performance with Donkeycar https://www.youtube.com/watch?v=9yy7ASttw04
Nov 9
RT @JoeSpeeds: Sat Nov 6 Virtual DonkeyCar (and other cars, too) Race. So bring any car? @diyrobocars @IndyAChallenge https://t.co/nZQTff5…
Oct 31
RT @JoeSpeeds: @chr1sa awesomely scary to see in person as our $1M robot almost clipped the walls as it spun at 140mph. But it was also awe…
Oct 29
RT @chr1sa: Hey, @a1k0n's amazing "localize by the ceiling lights" @diyrobocars made @hackaday! It's consistently been the fastest in our…
Oct 25
RT @IMS: It’s only fitting that @BostonDynamics Spot is waving the green flag for today’s @IndyAChallenge! Watch LIVE 👉 https://t.co/NtKnO…
Oct 23
RT @IndyAChallenge: Congratulations to @TU_Muenchen the winners of the historic @IndyAChallenge and $1M. The first autonomous racecar comp…
Oct 23
RT @JoeSpeeds: 🏎@TU_Muenchen #ROS 2 @EclipseCyclone #DDS #Zenoh 137mph. Saturday 10am EDT @IndyAChallenge @Twitch http://indyautonomouschallenge.com/stream
Oct 23
RT @DAVGtech: Another incident: https://t.co/G1pTxQug6B
Oct 23
