    You don't really need a gimbal for 3D mapping. Because you're taking still pictures, the software will fix any tilt when it stitches them together into a 3D model.
    BTW, we're going to release a one-button 3D mapping tool in DroidPlanner in a week or two. It's amazing.
    • Do I need a sonar system? I don't understand how to say to the quadcopter to go to 50m (for example).
    • Many projects I seen use APM2. Does the Pixhawk will be correct?
    • Do you think than it will be correct if I will not use a gimbal but I wil use the Shouyeh Gong's solution?
    • Can't wait to see it, but will 3DR be allowed to export it to other than Canada?
    • Will keep an eye out for that!
    • Thanks for anwser. How can I fix the camera? Is there a clean method?
      DroidPlanner seems to be cool. Does my setup will be correct with this app?
      • I also use Canon S100 to take straight down still photo for mapping. I made a camera holder with 2 pieces of carbon plates (plastic or styrofoam or thick cardboard plates will do also) a little bigger than the camera, the one in front with a hole for the lense, then tie the camera and 2 plates with anything you got. Then glue a big piece of Velcro on the back of the plate behind camera. Next, attach a small carbon plate to the bottom of the quadcopter just like the plate for battery (I use 4 aluminum tube but the 3DR quad will need other method), then glue the other side of Velcro to the carbon plate, then simply press-attach the camera holder to the carbon plate. You can use cable tie as additional insurance. Velcro will also work as damper but you may still need to set the speed at 1/500 even 1/1000.
        Another point, you may want to check the flight time of the quad to see if it fits your need.
DIY Robocars via Twitter
Sep 9
RT @chr1sa: We've got another virtual @DIYRobocars race tomorrow at 9:00am PT. Two dozen autonomous cars will compete, four at a time. Ther…
Sep 4
Sep 1
Aug 31
Aug 31
RT @ExplorerRobocar: Sometimes, I am really a big kid!! Having fun with my virtual RC car on the @diyrobocars track 😜😉, by using the « AR R…
Aug 24
RT @grepLeigh: @donkey_car @unity3d @TensorFlow ~1050 episodes into training, my agent learned to erratically drive in the left lane. 🤖😆 ht…
Aug 24
RT @EclipseCyclone: Sweet! http://Robotec.ai high performance #ROS 2 @unity3d #CycloneDDS bridge for @AutowareFdn @SVLSimulator now…
Aug 24
RT @a1k0n: My car had a lot of trouble getting around the track at the last @diyrobocars event -- only one actual finished lap during the r…
Aug 24
RT @SmallpixelCar: This is the run time map https://t.co/VzykOkUt2G
Aug 24
RT @SmallpixelCar: Made a lot progress on Warm Spring Raceways track. Almost finished one lap. https://t.co/nUVpufZQyP
Aug 24
RT @AntonioRobotics: Super fun time seeing these autonomous cars race at @circuitlaunch for the @diyrobocars quarterly meet up! The demolit…
Aug 15
RT @a1k0n: I thought my dumb localization code was still working at the new @circuitlaunch track, but it was just *barely* working. I shoul…
Aug 14
RT @DAVGtech: Recording of entire in person @diyrobocars race today @circuitlaunch. Fast forward a couple hours to go straight to the racin…
Aug 14
RT @SmallpixelCar: This is the run time map. Very noisy Lidar signal https://t.co/bAbeVUMi10
Aug 14
RT @SmallpixelCar: Today’s race with @a1k0n at @diyrobocars We both decided jumping over the wall was the way to break the 11s lap time. Th…
Aug 14
