DX6I Flight Modes
Hey guys,
I am running the DX6i with the APM 2.6 on a quadcopter I have just finished. How can I set up the F-MODE switch (0-1) to control more than just 2 flight modes? I have read up the excellent information about the DX7 and DX8 but the DX6 is considerably different. I am okay with using more than 1 channel to do this if necessary. Even if i can only get 3 flight modes that would be better than 2! Thanks in advance!! - Erik
  • I am not sure this will be exactly what you need but many times I need what would be close to a 3 pos switch on the dx6i. Most of the time I have flight mode on the 5th channel (gear). This is 2 modes with gear switch. Then I turn on mix1 (ACT) and set mix gear>gear, rate D -80% U 0%. Put it on sw ELE D/R or FLAP. This makes for 3 modes using the 2 switches. Pretty simple and not efficient but gives 3 positions at the fingertip. You can use mix2 as well and more combos but that should give you a feel. There is a really good 6 mode mix tutorial for several radios around here somewhere just can't put my finger on it at the moment. You can also set the U value to get a 4th mode if you need it of course.
  • If you mix channel 5 and 6 you will have 4 modes. Then if you switch off your transmitter you can set up a fifth mode to activate.
May 21
Azjeg liked Azjeg's profile
Apr 27
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
