I am new to RC plane and UAV. I want to build a UAV myself. I bought a Dynam HawkSky as my first platform. Everything is fine, but the ESC and brushless motor. I turn on the TX and put the throttle in the off position. Then plug in the battery to ESC. Then move the throttle up and down. The motor only turns after I pass the middle position and it runs very slow and discontinuously. It is like there are some forces against it.(two force push one direction, one force push the other direction). I check the servos and they works fine and I can control them through TX. So I think there might be something wrong with ESC or motor. Is there a procedure that I need to follow to set up TX with ESC? or Is there any way to check ESC or motor individually?
Thanks! I appreciate any help!
contacted the seller and get ESC replaced. But think about upgrade it.
http://www.graysonhobby.com/catalog/microjet-combo-microjet-p-765.html
