I'm making some thoughts about upgrading the easystar.1. More space for you know what.2. Easy to get your big fingers inside the fuselage.3. Able to separating the carbon fuselage from the other part of the model, so it will be easy to get inside. (front/belly can be removed).4. Able to place heavy paylod under the wings. (battery) Also the IMU.I know it's a little crasy, but I think it will make the model more useful for UAV / FPV flying.I have made a quick mold.
Any thoughts?
    Hi Colby
    I have been building a better design for the easystar, more like the orginal just a little shorter.
    I also made some test for the Glider as well:
    I thought it was possible to make the fuselage and maybe sell it... But I found out that it's too much work, so price will just be too high. I hope it will give people some ideers and i'm ready to help out if there would be any questions.
    Krzysztof:
    I know this is Easystar. (EASY T REX "small brain big mouth"). front 4 cm shorter than original.
    About Easyglider its still under con.. much more work.
    David:
    There will be an inner carbonfiber box glued to the foam then the fuselage in carbonfiber will be able to bed fixed with small bolts.
  • T3
    The concept is good, but the nose design looks scary.
    Also I believe the nose is unnecessarily long. The cameras are so heavy they dont need to be placed far front, long nose worsens dynamic stability on pitch, and there is plenty of space under the wing anyway.
    BTW this is EasyStar not EasyGlider.
