Developing the frame for a heavy-lift drone presents multiple technical challenges. First, as all-up weight increases, it becomes difficult to evaluate the deformation and fatigue characteristics of the frame under extreme conditions, making structural margins hard to define. Second, the power system draws high current, and even a slight increase in wiring contact resistance can raise operating temperature and compromise electrical reliability. Third, most frame platforms are developed from scratch, leading to long validation cycles and high development costs, while hidden reliability risks such as vibration during transportation are easily overlooked.
To address these challenges, EFT company recently completed two verification tests on the X2800 heavy load frame: an extreme load-bearing test and a 9-hour simulated road transportation vibration test, both fully documented on video.
Test 1: 400kg Extreme Load-Bearing Test
Structural margin is the first hurdle in heavy load frame design. In this test, the X2800 frame was suspended by slings with 4 standard 100kg weights, totaling 400kg — more than 1.3 times its rated payload of 200-300kg — to simulate loading conditions beyond normal operation.
Inspection under full suspended load confirmed:
· No visible deformation of the high-strength metal fuselage and center platform; the overall structure remained rigid;
· The 80mm carbon fiber arms showed no bending or cracking, with loads evenly distributed across all arms;
· All arm-to-body connections and fasteners stayed tight throughout the test, with no loosening or slippage.
The results demonstrate that the frame retains ample structural margin beyond its rated payload, providing a safety boundary for dynamic loads during maneuvering flight of 200-300kg-class aircraft.
Test 2: 9-Hour Transportation Vibration Test
Heavy load drone frames are large and heavy, and are typically delivered by road after leaving the factory — making the sustained vibration of long-haul transport a real challenge for both structural connections and electrical terminations. In this test, the complete frame was mounted on a transportation vibration testing machine and run continuously for 9 hours, simulating road transportation conditions well beyond typical shipping duration.
Post-test inspection confirmed:
· No loosening, cracks, or permanent deformation; all modular connection points remained tight, validating the reliability of the modular design;
· The cold-crimped and bolted wiring terminations maintained low contact resistance with no contact faults, ruling out vibration-induced electrical hazards;
· The airframe showed no impact damage or displacement of any component.
These results also indicate that the frame can withstand the shock and vibration of delivery transport, and provide a solid reference for structural stability under long-term flight vibration.
Product Highlights
The X2800 is a large quadcopter drone frame designed for 200-300kg-class applications, built around four principles: high payload, strong expandability, easy development, and easy maintenance:
· Payload capacity: Rated for 200-300kg and verified by a 400kg extreme load test; suitable for aerial lifting, logistics transport, emergency firefighting, and other drone-for-business scenarios;
· Structural strength: High-strength metal fuselage combined with 80mm carbon fiber arms delivers excellent resistance to deformation with ample structural margin;
· Modular design: Fuselage, arms, and landing gear are modular and quick to disassemble, simplifying assembly and cutting maintenance costs — damaged modules can be replaced individually, reducing total cost of ownership;
· Electrical system: Cold-crimped, bolted wiring terminations keep contact resistance low and temperature rise minimal during sustained high-current operation; neat wiring and good electromagnetic compatibility ensure stable operation of high-power propulsion systems and flight controllers;
· Expandability: A large battery bay accommodates batteries of different models and capacities, allowing customers to configure propulsion solutions flexibly for diverse mission requirements.
Conclusion
With structural strength and transportation reliability already verified, the X2800 allows development teams to focus on integrating propulsion, flight controllers, and mission payloads directly on the platform — significantly lowering the barrier to developing 200-300kg-class UAVs. Whether you are building a big quadcopter drone for commercial operations or sourcing professional-grade DIY drone parts for a custom heavy-lift project, the X2800 heavy load frame is a proven starting point.
Contact EFT for detailed specifications and technical documentation.
