For large-scale farmland and plantations,yield, labor costs, and time efficiency directly determine farmers’ returns. With the development of drone technology, drones are taking on more operational tasks throughout the entire agricultural production lifecycle. Such as seeding, pesticide spraying , fertilization and transportation during harvest—significantly reducing labor intensity.
Z80 flagship agricultural drone is all-in-one design , can quickly switching between spraying, seeding and lifting functions .One platform, multiple applications—delivering flexible, efficient, and cost-effective performance for modern agriculture.
Now, let’s see the Z80 in action.
Z80 Spraying System
For spraying, the Z80 carries an 80L tank with dual flexible impeller pumps and four high-power centrifugal nozzles, producing a 36L/min high-flow atomized spray. Large 63-inch propellers maintain stable downwash airflow to minimize drift , ensures thorough, uniform coverage on plant root zones and leaf undersides. Droplet sizes range from 50 to 500μm, the fine atomized droplets prevent leaf chemical burn, reduce chemical usage, and deliver precise, optimal spraying results.
Z80 Spreading System
In seeding and fertilization tasks, the Z80 features a 120L hopper capable of holding 2.5 bags of fertilizer in a single load. Its new auger-style spreader delivers up to 400KG/min, handling seeds, fertilizers, or feed smoothly and evenly. Frequent reloads are minimized, material is applied precisely, and coverage is consistent, saving time and reducing waste.
Z80 Lifting system
Every second counts in transporting harvested crops,rapid handling from field to transport preserves quality, reduces waste, and boost farm profitability. For lifting and transport, the Z80 swaps to a smart lifting system with built-in weight sensor to prevent overloading and simplify job tracking. Shock absorbers enhance flight stability, and a one-touch fuse helps the drone escape if cargo gets stuck. Operators can choose manual control or automated point-to-point flights, and the drone supports dual-operator collaboration for safe, reliable crops transport.
Z80 Intelligent Control System
The Z80 is controlled via the upgraded EFT 4.0 app, offering a clean, intuitive interface and smart task management. Flight modes are automatically recognized, interrupted missions resume along optimized routes, and KML import supports precise operation. The system continuously monitors module status, giving operators a smooth experience across all tasks.
Z80 adopts an all-in-one design, integrating an industrial-grade truss frame, screw-type high-current power board, and quick-release body clamps etc. these ingenious structural details ensure stable and convenient operation. Efficient and versatile, the Z80 makes large-scale farming easier and more productive.
