Eliminate blue screen of death with minimOSD?
Hi guys!
I just bought a cheap 7" monitor for FPV. Of course it goes to "Blue Screen of Death" on weak signal.
Could a minimOSD be used on the ground to just pass through the signal and it would resend the sync signal so the monitor would never know the signal is weak/lost?
Is there an even easier/cheaper way to do this? My 5min googeling didn't give me any good results...
  • Well, after some more research, I've found out that someone had already tested that approach and it did not work...
    http://www.rcgroups.com/forums/showpost.php?p=22479760&postcoun...
    If I eventually find a cheap solution I'll post back here.
    RC Groups - View Single Post - What Device can prevent the " BLUE SCREEN " on LCD monitor when vide…
  • Hi Jon.
    My couple hours googeling tend to agree with your 5 min...
    As of now, the solutions I've seen involve broadcasting the signal as RF and tunning it in a TV with a receiver (not useful for cheap LCD monitors) or using a device to "Time Base Correct
    " the signal, which requires expensive (~$200) equipment...
    Some also suggest that a DVR in series with the video signal might do it, but I worry about the delay and it's not so cheap...
    But I do think you are onto something. Using a "dummy" minimOSD as a video regenerator might be the answer. I'd like to see someone that has it, try.
    Following!
